On 12/5/2019 at 1:09 PM, Ady Candykitten said:
Just got off the phone with Michael Valle (Service Manager) at Gunn GMC/Buick, and they may possibly buy the truck back.
Ever have the issue corrected?
Really?  For a body alignment issue that can be corrected?  Wow.
Got the box aligned on my 2019 at4, it had to be moved over half inch from drivers side to passenger side,  looks way better now, iam happy, just the brake squawk noise I get first few minutes when it’s cold , dealer said it’s normally operation , my 2014 didn’t nor did my 2007, 2005, 1999, or the 6 other GM trucks I’ve owned from the 80’s and 70’s,
2020 AT4, I get the early morning/cold squeal the first 2-3 times I brake.
So today i was at the locale dealership picking up some special order parts. I asked for the parts breakdown on the bed shims/bolts,the gal asked why ? I was in the service department yesterday for the bed alignment problem on my truck. Basically the service department manager told me your shit out of luck you drive it off the lot like that its on you. The parts gal said did you try the other dealer in town,i said ya that will be my next try.Then she started to look for any bulletins on it and guess what [#19-NA-257 ] Pickup Box Out of Alinment  Poped up. So i went back to the service writer and showed him the bulletin, he made a copy and said he would get back to me, so we will see how this turns out. So if your dealing with this BS problem on a 50,000 dollar truck get a copy of this  #19-NA-257   when you head in to the shop to get them to fix it.
Concerning th bed alignment.  It's a 1 hour job  did mine myself to avoid all the BS. Mine is a 2020 GMC Elevation.
There is a plastic guide pin in the front right corner.
Loosen  the six bed bolts until they are almost out. Leave them in so you don't  contact the cab with the bed. This fixes the horizontal  adjustment. You need shims for the vertical.
Left the front right corner  about an inch take a hacksaw blade just the blade and cut the plastic  guide pin on the top of the shim between the bed and shim..
Drop the bed ,move where  you want tighten it down. Done
Edited by Mark Peterson
Misspelling
Brake pad squeal is a common issue die to the materials used in modern brake pads. Especially ceramic brake pads.
My dealer knew right away how to fix it. Took it in today and problem solved. Tech said a bulletin came out about it last month.
What does your work order say specifically regarding work performed?
  • 3 months later...
Just bought a 2020 Chevy LT Trailboss crew cab and the bed is misaligned exactly like yours. Appear that wasn’t on the quality control checklist. Did you get yours fixed?
Has anyone had any damage done to their truck getting the bed aligned?  Mine is in the shop now and I was told it has to get sent to their body shop.  I’m a little nervous about it.
So who all has had the repair done according to the TSB? Purchased a 2020 Silverado 2 weeks ago and was wondering why things looked off in the drivers side mirror. Lines don’t match up and if I stand behind the truck, the drivers side rear wheel sits in the fender well further than the passengers side rear does. When measuring, drivers side of bed appears to be about 3/4” higher than passengers side.
Took it to dealer this morning and have appt for next week. Also called the dealers body shop, they told me to bring it by and let them look at it. I feel more comfortable with the body shop working on it rather than someone in the service dept.
Just noticed this on my 2020 LTZ. Looks to be the same issue as many on here; driver’s side of bed is sunk in about 1/2” and also about 1/3” high of the “body line” on the cab.
I’m taking it in along with the TSB (thanks for finding this btw) tomorrow or next week. Will report back on how it all goes.
    DaleB
    DaleB
  • Who's Online   7 Members, 1 Anonymous, 1,541 Guests (See full list)
    • Hi all - my current truck is a 2022.5 1500 High Country 3.0. I bought the truck used last year. After doing some digging, I noticed that my truck's software is stuck on the original build from 2022. I have no available software updates. I talked to my dealer about this and they recommended not trying to force an update since the 36,000 mile warranty is expired. This is a big bummer since there have been many major releases since that have fixed small issues and improved speed/usability.   For reference, the current software build number is: full_gminfo37_gb-user 10 W158E-W164.4.2-QIH22B-563.3 158 release-keys Has anyone had a similar experience? Should I just forget about it and move on, or try a different dealer?
    • Sure. Buy it for me 🤣
    • Using zip ties but 2-3 they snap due to sharp edges. Just using a shoestring. Last longer. 🤣
    • I ordered the Snap On...waiting for it to come in later this week or early next week.   New front cover, new crank seal and new balancer are on. Water pump, pulley, fan, hoses, and plastics reinstalled. I can move forward knowing all my timing marks are dead on and the front engine is hopefully sealed better than it was. Take 2 with the water pump...trying high temp thread sealer on the lower bolts.   Rebuilt injector and new-new regulator is in, it looks like new. Top intake reassembled and all the bits are reconnected and snugged down.   Thinking about knock sensors again, I located both of mine and, there's your problem, Francis... The driver's side one is broke, plastic is bashed in, part of the wire is bare, and it appears to have been damaged like that for a long time. I saw the wire but didn't think anything of it. The knock sensor might not be my pulled timing issue, but it sure looks suspect. It must still be conducting, otherwise I'd expect a CEL. But perhaps with its sacred crystal inside exposed, jilted and dirty, maybe it's sending mixed signals. So I'm waiting for one of those and a new pigtail to come in. Pass side sensor looks good, except for the spark plug wire resting on it (!). The plug wires are healthy so it shouldn't be causing an issue, but I separated them and added zip ties to nearby looms to keep everything well apart.   So, I'm down to installing a knock sensor AND, oh, replacing the exhaust and cat. I actually think that's going to be fairly easy, it's all bolt-together, all new stuff from Walker is laid out on the shop floor ready to go. Hopefully have this thing on the road again for the weekend.   My luck? It will still be leaking oil, coolant, pulled timing, intermittent CEL for running rich, or it probably won't run at all -- because that's how this project has gone.   I've never worked on a vehicle so ...hurt? ...cursed? in my life. Everything has been effed with SO HARD, but I think...knock on wood...I've managed to undo all the backyard stuff and we're almost reset back to "just" an 80k mile, 30 year old Blazer.
    • Yes. You need to check out that thing, and the hub further.
