Oil Pressure Gauge
tmar480
I have a 2018 GMC Sierra with 8,000 miles on it so far and I've noticed recently that my oil pressure gauge is being a little weird. I just got a oil change 2k miles ago and when I'm at idle at a stop light or whatever the pressure gauge drops down like 3 notches before its at 0 then as soon as I hit the gas it jumps back up to the normal line. I thought I was just low on oil and I put 2 quarts in which was a little more than I needed but I'm not worried about that for right now but it is still not at the normal line when at idle. So it can't be that I am low on oil. Is this something that is common with these trucks or is something wrong? I'm new to the whole GM truck thing so I'd thought I'd ask on here before I jump to conclusions. Please let me know if there is an easy fix or something!
Thanks guys!
Your pump has variable output based on demand. It's not going to sit at a constant pressure.  Make sure your engine oil level is at the full mark and not way above. Next time just check the oil level prior to dumping in two quarts. If it's full, more oil not going to help.
Edit: What pressure is it at? Your description of "3 notches"..... are you saying it's at about 10 psi, the first mark above zero. Or the the third mark which would be about 30 psi
Well I didn't add two quarts of oil just because my oil pressure gage wasn't level. I've been burning a stupid amount of oil recently cause I drive on the highway a lot to work plus with the AFM burns a lot of oil as well. I was below my lowest dot on my oil stick hence why I added two quarts.
Yeah Id say about 30 PSI maybe 25 depending on the day honestly.. After I added the oil it went up to around 40 but fluctuated when at idle.
Not sure what the recent spec is for these engines but it's likely to be around 10-12psi for every 1,000 rpm. So if you are at 25-30psi at 500-600rpm at idle with these new variable pumps, it's perfectly normal.
Alright, I just didn't know if it was normal for that oil pressure gauge to be fluctuating like that. Sound like its normal from your description and I shouldn't be worried.
Based on your additional info, I'd say you're "normal", except for going through oil as you mention
Yeah I've been reading how much the AFM burns oil and I'm waiting to get the Range AFM Disabler soon. But I continue to check my oil every 1k just to make sure I'm in the clear. But I appreciate it.
1 quart every 1000 miles is kind of alarming.
I would have it the dealer having the engine checked out, AFM does not burn oil at that rate.
5.3 in our 16 Tahoe, 6.2 in my 18 Silverado, both "loose" .5 to a quart every 5000 miles.
    • Thanks for that, yes just because I could I measured what came out just to give me some guidance although I already knew to expect it to take at least 9.5 to just throwing in the whole 10 quarts off the shot and doing a one and done heat cycle to drop out the excess to get to the proper level. I don't recall exactly now what I measured that came out but was less than I put back in, I knew I spilled some on the garage floor but the main part was that I was thrilled in the discovery I did not have to touch my exhaust to flex it down. The gasket manipulating is a pain of course to create that clearance to take the pan out and put back in but its all very doable if one is careful and not forcing the gasket to flex too much. From the quote I got at a transmission shop of 900.00 here in Canada ( never asked at the dealer what they charge ) I saved 700.00 doing it myself after paying for the supplies so that to me paid very good wages !, and I knew what fluid was put in and that I had changed the filter and that the level is correct without any doubts.
    • I do have one of the AFM diasable box, using it for last 1.5 years.
    • I found a setup that lets me open the cover partway with racks installed, using side-rail-mounted systems for easy access.
    • Typically its said and I agree so far that the engine oil drain plug oring is not required to be changed out unless you see some damage happening to the oring as apparently the oring lasts well. The dealer I have been getting a few parts from never even stocked the oring but instead stocked the whole drain plug that comes with a new oring which for the dealer is easier because they just throw in a new drain plug if there was any question about damage on it as well and charge the customer accordingly but again only if it is needed.    Also a hint about the drain plug oring to help it last vs a risk of causing damage to it, after its been removed and wiped off or washed off ( that is a whole other topic about some solvents damaging orings because some solvent types do ) to make sure to relube the oring with a bit of new oil so that it won't "grip" on the sealing surface of the pan and needlessly stress out the oring. Its no different than putting some oil on the sealing ring of the engine oil filter. So I just grabbed a new drain plug to have on hand although more recently bought just the oring as well but as its special it costs half the price of the drain plug ... !   Since you mentioned the hate to be empty handed theme, I am not sure what you have in the way of filter removal tools as I like using the exact sized for the filter steel 1" wide band with side to side swivel handle filter removal tool, and it can be used to snug up the filter without risk of damaging a filter as well ( its probably a lisle brand I have ). The drain plug hex size is 15mm and I always like using a 6 point socket if I have a choice and with this truck I've been using just a 3/8 ratchet that has a fairly long handle. Do you have a funnel that will work to pour oil in as that is definitely the short coming bastard part about the design with that fill port on the valve cover on such an angle that no normal funnel will even work. There are adapters and things on the market that will set into or screw into that fill port, I didn't want to deal with US shipping as that is all I was seeing at the time so caved and bought a Lisle brand multi vehicle fit adapter funnel kit and it really works well but there are much less expensive adapters out there that work in conjunction with an off the shelf funnel that would do the job also. Now that I have it, I like how it works and works so slick with the shape of the Amsoil 1 quart containers I have now switched over to. Whatever you do, have a funnel system of some sort as you will be swearing if you dropped the oil and then realize you have nothing to properly pour new oil in without spilling it all over the engine !.     Other comments, quite a bit of oil flows out down the filter when its cracked loose due to the housing above the filter so let it dribble down the filter until it slacks off flow and then remove the filter to create less possible mess. It seems these engines can sit for quite a while and drip and if you have time let it sit there and drip out of the engine as much as it wants. Also a good time to grease the 9 zerks on the front end, that's my typical practice anyway to grease the suspension and steering each time I change the oil. And remember to reset the oil change minder ( not something I am used to doing with older vehicles and equipment ).
    • I really did not measure what came out. I carefully followed directions to check level after i did the spill and fill and filter change. I used 10 quarts. 9 was not quite enough. My trans temp was about 175 when I checked it. Truck sitting in my driveway very close to level where I always check oil pretty much every time for consistency. My driveway is just ever so slightly downhill to run water to the street.
