Just now, GETGONE said:
So all that oil just magically ended up in the catch can when you say no oil gets out of the PCV? You realize there is NO valve on the valve cover. It is a baffled hole.
I agree to disagree, not interested in arguing.
  • Haha 2
Sorry Mickey. Couldn't help myself :crackup:
On 12/7/2021 at 8:09 PM, M1ck3y said:
T1's have 0 need of a catch can. Valve cover's filter out any oil (same as k2). But the T1's don't have a pcv valve coming from the valley. Which is largely responsible for any oil that creates carbon buildup.
Absolutely!   What people are thinking is oil condensate is fuels dilution. Use a better oil, tune your engine up.  Generally only  need for blow-by capture or catch cans are racing entities who have highly modified crankcase pressures, flows, piston speeds, low tension rings etc.
Believe it or not I used to analyze what most think is oil and majority was fuels residuals and associated condensation attracted to that fuel.  The oil and carbon will color what is seen in a catch can but its minority oil tested across many OEM's for competitive comparison.
I quit following catch can threads after repeatedly making this point to deaf ears. Perhaps your background will be more effective. :dunno: But I'm not holding my breath. 😉 :P
  • Sad 1
It's not his facts. It's how he argues them 😂
In all seriousness though, it really doesn't matter what he says. When he speaks, it screams I'm smarter then everyone. Not unlike you 😉
And now it seems you two roll through this forum together!
  • Haha 2
 On the topics of tribology and fuel science?
Could that be because he is?
It's his field. Ya know, the one a guy butters his bread with?
Can't say what he knows about the physics of black holes though.
That might be a Stephen Hawking thing.
  • Thanks 2
No, that's not what I see.
I agree to disagree 🙂
  • Haha 1
For me to agree I'd need to know what you disagree with.
Spell it out cause I'm slow.........
You're not slow.
You're like a young cheetah with its first hard on 😉
  • Haha 1
15 minutes ago, M1ck3y said:
You're not slow.
SO....it's a trap you baiting. I though so. I'll pass. You have  nice day.
  • Confused 1
?... That was meant to be a compliment 😉
You two rolling through this thread is really offending my delicate sensitivities... my snowflake is melting or was that chiffon back in the day.  🤗
  • Haha 3
This topic is now closed to further replies.
    whenindoubtuseahammer
  • Who's Online   1 Member, 0 Anonymous, 330 Guests (See full list)
