Installed under seat storage compartment
I’ve been looking at these since I bought my truck. Had one in my old Nissan and really missed it in this truck. The dealer wanted $225, I found this one on Craigslist for $100. Took all of 5 minutes to install. The plastic is a lot thicker and rigid than I thought too. Fits like a glove!
2484480-C-BD5-C-40-AD-8-C4-B-574-D0-D3-D
D04-EB13-D-7-E88-43-B3-A6-AA-73-A5686-F7
63-B3-BF09-6-C0-B-4858-B48-A-FDD1-F187-C
C7-BF3279-A53-E-4776-99-B6-2-C5-EC90-F86
Had it in my tundra and it was the first mod I did to my Sierra. I also got the oem one and it fit like a glove into the gm all weather mat molding.
I bought one on Ebay for my 17 that was non-oem half the price and fits great.  Nice to have for sure.
