 I have a 2016  GMC Dinali 6.2 L and I was just wondering if anybody was having problems with trying to get  head   Gaskets   I took my truck into the dealer for a tick in the engine and they said it was my Lifters and Cam  and I was told it would take four days to repair that was two weeks ago they are telling me that the head gaskets are on back order and I was just wondering if it is bad to have my engine tore down for two weeks? And do not know when head gaskets will be available to finish the job.
Not bad to have engine open as long as debris and water stay out. And I guessing they are speaking of factory part number head gaskets.
 Yeah and the truck is parked in the back lot of the dealership  said they cannot get a gasket anywhere
Warranty work I am also assuming? Because I can order a performance brand gasket this minute. Not that the GM MLS style is bad it is a great part. Just saying there or option if not a warranty claim.
It is not a very comfortable thing to know head gaskets are on backorder. That means GM is going through a lot more of them than they had anticipated, signaling poor longevity of the new LT engine family as compared to the LS engines. I would ask them for a loaner truck or to use an aftermarket gasket if you are going to be down for a long time. All these lifter/head issues make me want to dump my personal truck before warranty is up. Don't even want to know the cost of a new L86 dropped in with no warranty. Probably about $12-15k in Canada after labour and tax. Hope it works out well for you. They are all junk these days no matter what emblem is on the grill.
Yes theybare available just the way that dealer gets then is delayed. But it isn't uncommon for head gaskets to be backordered. The stock MLS are awsome and even high end builds still run stock but spray them and have head studs.
For as little as they cost, i would buy them myself off amazon, ebay etc and hand deliver to dealer so they can get my truck back to me asap.
They can always reimburse later.
Before doing (bringing parts in), ask if they will still warrant the repair.  Wouldn't surprise me if they said no, particularly if the gaskets aren't OEM...
Wouldn't surprise me either if they said no, even if the gaskets were OEM.
It's all about liability these days. :loser:
There would be no paper trail leading to the outside sourced gaskets.
Still no head gaskets  went to the dealership today to get some stuff out of the truck and I looked inside my truck and the top end of the engine is in my backseat with the seat up With a blanket between my carpet and parts  don’t know if that’s  common practice or not but it didn’t look good and my truck smells like old oil I’m not too  impressed with this dealership right now .
I would Blow a Gasket if I were you!
Engine parts inside the cab, in the back seat?
Oil chemicals will certainly permeate the interior over a short amount of time leaving odors.
When this is all over do yourself a favor and find a New Dealer.:thumbs:
    250.3k
    user087
    user087
  • Who's Online   5 Members, 0 Anonymous, 987 Guests (See full list)
    • Thanks @newdude, guess I'll keep looking.  Test driving so many trucks that have obvious things broken, I'm thinking "if they couldn't even be bothered to fix the power seat," what else is broken".   Just drove a 2021 where the power seat motor was grinding/binding and wouldn't do anything but make a terrible sound.   An owner that puts dents on the bumper, doesn't fix a seat motor, and had spotty service intervals (along with missing major services) doesn't give me the best of confidence.   Amazed at the number of people that will finance a $60k+ truck, run it into the ground, then trade with a loan balance (every single one had "loan/lien reported" on the CARFAX at the last year of registration).
    • Not true! I have been runing them since 2006 F250! suspension component that works as a sway bar, a traction bar, and a helper spring points directly to the RoadActive Suspension (RAS) kit. Works as a sway bar, a traction bar, and a helper spring.
    • Here's a starter kit:    CC Jensen, a Danish oil testing Concern gives us the following guidelines:   ISO 14/12/10 Very Clean Oil ISO 16/14/11 Clean Oil ISO 17/15/12 Lightly Contaminated ISO 19/17/14 New Oil ISO 22/20/17 Very Contaminated and not suitable for any service.   In addition CC Jensen gives a table showing how engine life is increased by cleaning up the oil. For example cleaning the oil from 19/17/14 to 13/11/8 will extend motor life by a factor of 6X.   But even cleaning it two “Life Extension Classes” will double motor life. So perhaps giving those classes would be useful:   21/19/16 20/18/15 19/17/14 18/16/13 17/15/12 16/14/11 15/13/10 14/12/9 13/11/8   *************************************   https://testoil.com/program-management/setting-iso-cleanliness-targets/   Third paragraph from the bottom will give a starting point.    Your next question should be, okay 10um at what Beta ratio and the answer is in the graph Beta 75.   Then the next question is what is your chosen filters profile? (Purolator PL series below) The red dot is Beta 75. This was the information I obtained from MANN a few years ago. So the best filters, Purolator One, AMSOIL EA, FRAM Ultra, Royal Purple, Bosch Premium should get a doubling engine life over filters like Purolator L, any service filter from any quick lube, WIX, NAPA, STP, Mobil 1, Purolator BOSS.    And as noted by CC Jensen a 2-5 micron @ Beta 200 bypass system has the capability of a six fold improvement. AMSOIL has such a system as does Donaldson.       Now having said all that testing is the touchstone. Test the oil NEW and test it with your chosen filter. Then test over milage. Do the work, get the result. But understand this in NOT absolute BECAUSE this is one factor in isolation.   Example:    A valve spring supplier can state that with cam X and a valve train of Y grams the valves will not float to 7K rpm. is that true if the builder choose a system 20 grams over limit? Common sense must be used and limits understood.
    • This doesn't look like a GM truck. Not needed on a HD truck
    • It varies a ton around me. Some places are still at $5.00 or higher and others are way down into the $4's.   Offroad diesel was $4.02 at the one station I passed today.
