I have a 2019 AT4 that every time I start the truck and select Nav, I get the following message:
SD card message: Once initialized, this SD card can only be used for navigation in this vehicle.
My my only option is to hit the confirm button on the screen and then my Nav map will load with no further issues. Does anyone know how to clear this message so it doesn’t show up every time I start my truck. Thanks in advance for the help.
12 hours ago, cbacarisse said:
Mine did that and once I set up a user it went away.
Thanks for the feedback. I did set up a user profile on my truck recently, but am still getting the message.
There is another thread on this. The problem is that the card is locked and cant be written to. The truck is trying to initialize the card and write data to it but it cant. Floppy disks used to have the same thing back in the day.
Pull the card out and look on the side. There is a little tab. Move it to the unlocked position, put the card back in, start the truck, and then it will happen more time, press confirm, and you shouldn't see it again.
Same thing happened with my truck.
Edited by cullan
Thank you, this cleared it.
  • 8 months later...
Thanks very much for posting this. Duh on my part.
After updating to 807 and replacing the SD Card and card receptacle, GM now wants to replace the radio control module, which requires two visits, one where they need to get the number off the current unit and another to replace same.
I want them to go to back to 509, the last known working version which had no problem at all.
Has anyone been successful in getting a dealer to go back to an earlier software version?
Any other updates anyone? Please provide the latest status.
Thank you.
I am having this same issue.  My dealer too wants to replace the radio module.  I am not thrilled about them tearing apart the dashboard in my 9 day old 1500 Denali.  Has anyone had any luck in getting this issue resolved?  Currently, the SD card has been replaced as well as the SD card reader.  Anyone able to help?
Similar issue.  SD card removed error randomly occurring riding down the road.  Not all the time.  However, I could make it happen error by disconnecting the USB cable from the truck side outlet.  At which point the USB ports (dash and console) were dead (no power; no Apple Carplay) until some time later usually sitting overnight.  Dealership replaced SD card today....didnt fix it.  So I demonstrated the issue to the tech, so they took it back again.  After an hour of waiting this morning they are replacing the radio module (I think).  I was told the dash had already been taken apart, so they gave me a loaner.  New parts to arrive on Monday, so we'll see if its fixed then.
Hoping this fixes the issue, but I am going to be meticulous in making sure none of the trim is scratched or loose.  Only had the truck for a month...
  • 7 months later...
I just got my 2021 AT4 and was getting this same message and unlocking the SD card did the trick.  My question is why was it locked to begin with, is this something the dealer did inadvertently or did it come from the assembly line this way.  Anyway, my problem is fixed thanks for the post.
I am having the same issue. I have a 2021 AT4 with 600 miles on it. The dealership told me that the SD card needed to be replaced. So they are ordering me one in. At the same time I had a check engine light come on and on star told me it was throwing a P00C7 code. I had a 2019 AT4 and had nothing but trouble with it. The dealership told me that it was uncommon to have this many problems with this truck, that’s why I traded for a new one. Now I’m having problems with the new one already. I’m starting to loose confidence in GM.
I fixed it in my 2020 malibu 2.0l so i bought new 16gb sd card from dollerama for $4 and copy the gm navigation sd card to new one make sure u copy all the system files check for hidden files too copy all and before u copy format to fat32 with cluster size 32k than name the sd card as same as gm card showz it will fix all the problems and even make navigation system runs faster
  • 3 months later...
Where is the SD card located? Please and thank you!
    • Point of the post sir was that while both wages and cost are rising EVERYWHERE; the cost is rising faster EVERYWHERE than the ability to buy EVERYWHERE. We're not going down the location rabbit hole. I'm aware of what economic migration is. I've lived in four states including Texas.   It's what "Purchasing Power" means.   I'm not telling you what I think. I'm telling what the government, your government, data shows.   It wasn't an argument. It wasn't a suggestion. It was a statement of FACT. You are absolutely entitled to your own opinion. Your not entitled to your own facts. If you and I were, they wouldn't be facts.    fact /făkt/   noun Knowledge or information based on real occurrences. "an account based on fact; a blur of fact and fancy." Something demonstrated to exist or known to have existed. "Genetic engineering is now a fact. That Chaucer was a real person is an undisputed fact." A real occurrence; an event. "had to prove the facts of the case." The American Heritage® Dictionary of the English Language, 5th Edition • More at Wordnik   If you'd like to disagree call your Senator or Representative and let him know his departments are in error. But you and I? We are not doing this.
    • Probably a one and done post, but do you have a CEL on the dash? Was having issues with my transmission, fortunately only a week, and it turned out to be the transmission harness. Valve body was in good shape, so new harness with all the sensors attached, new fluid, and filter. Seems to have worked so far?
    • Two interesting tidbits of information which are NOT related were just released.   One, regarding the possible thrust bearing issues / engine failures with the 3.0. Demonworks just did a segment in which they believe they may have found "a" or "the" cause of thrust bearing failures: A missing thrust bearing. If the engine doesn't have all its thrust bearings from the factory, the missing bearing can cause extra play which ends up destroying a nearby thrust bearing which then sends metal through the engine.       Of other importance, Lake Speed Jr released some interest information regarding oil weight selection for the 3.0. Comparisons of:   AcDelco 0w20 Dexos D Mobil 1 ESP x2 0w20 Dexos D Mobil 1 ESP x2 0w30 Mobil 1 ESP x4 0w40. Mobil Delvac 5w40   Spoiler alert: The Mobils are PAO Ester -base and the ACDelco is a Group III base. Mobil shows lower wear in their tests for similar weights. Additive packages between 20-30-40 weight ESP's appear to be the same, but only 0w20 is Dexos D licensed. Wear is even more reduced with 30 and 40 weight ESP although all perform very well and resist shear and provide very similar viscosities within temperature operating ranges in the 3.0.   There are even more surprises, so just go watch it.
    • Hello Guys I'm new to the form,         I just put a 7-inch Rough Country lift on my 2016 GMC Sierra 1500 with the 5.3 and I also put a Borla exhaust on it. But I noticed when I'm in park or in neutral and then I rev my truck up really quick there is a bad click noise and I think it's coming from the motor somewhere. Anyways I got a video of it I will attach below I was just wondering if you guys think its rod knock or lifter tick or something like that because I know the AFM kind of made the lifters weak on these trucks.       Thanks!!!!! RIP - Chevy 5.3 IMG_6043.mov
    • We’ll have to agree to disagree. I didn’t experience or know anyone who had a decent car after 100K miles in the 60s through the 80s that were daily commuter vehicles. Unless they were collector vehicles. Of course things cost more due to inflation. But we also make more money. The biggest money drains these days are things people think they need today versus what we require back in the day. Like cell phones and internet as examples. Another example is where you live. Cost of living varies from state to state. I would need twice the money to live in NJ vs Texas in retirement. The car you recently purchased was less than my first car with inflation at 3000$ in 1973. I didn’t have air, electric windows, cruise etc. Purchasing power is equivalent, you just have to do the research.
