Actually, I've studied tires and their affect on MPG for quite a while.  Weight plays a factor, but it's not a huge factor.  Rolling resistance and aerodynamics are the largest contributors.
On my 2015 6.2L Denali I ran 22" Bridgestone Alenzas (street tires) 2/3 of the year.  That combo weighed in at something like 88-90 pounds per tire.  I easily got 21/22 mpg on the highway and 16/17 overall average.  I'm a spirited driver.
In the winter and when going camping I also had a pair of GMC 18" All-Terrain wheels with Goodyear Duratracs that I'd flip on.  Stock sizes.  Each tire weighed in at a much lower 60 pounds or so.  I would always drop 1-2 MPG with the lighter, off-road tire setup.  Much lighter, but the aggressive tread pattern hurt my MPG somewhat.
Now I have a 2021 6.2L AT4 with stock 20" Goodyear Wrangler TrailRunner tires.  I don't know the weight, I assume it's in the 60 pound range, but I know that my mileage sucks balls.  I struggle to get 17/18 mpg on the highway and 14/15 in mixed driving.  It's got to be a combination of the factory lift, aerodynamics, and non-highway tire.
Summary - my heaviest tire got the best mileage because it had the best aerodynamics and lowest rolling resistance.
Run 275/65/R20 Goodyear Duratracs with 2" level on mine. 34.5" tire that is essentially the most aggressive All-Terrain tire they make A.K.A. the best looking non-mud tire money can buy. Looks considerably more aggressive than Toyo Open Country, K02's, etc. Uber popular tire on other off-road platforms.
Lost about .5-1 mpg over the stock 275/60/R20 Wrangler AT
Worth every penny in gas mileage that I lose. Truck looks so much better that I would have gladly done it over again even if I was losing 5x the mileage.
If you are worried about gas mileage, you shouldn't be driving a truck. You could lift your truck 8-10" and throw on 37's and I'm sure you would still be getting 10-12 MPG although you would do much better with a deisel.
Edited by DustSierra
My past experiece has been 1.5 - 2.0 mpg loss going up 2" - the move up of the front and imact to areo is the biggest impact on mpg.
I just sold my 2020 AT4 Carbon Pro - 6.2L - here is a photo of my "life of use" mileage - About 45% of time I was towing - half of that was enclsoed 24' trailer at 7,000 - 10,000 lbs.   Towing mileage in and around S.Cal hills was 6.2-6.5 mpg - got about 8 on flat ground and 4.5 +/- on hills.  I had 2.5" BDS lift with stock Duratracs - great truck - but with 24 gallon tank and poor mileage - had to stop 150 miles or less for gas with enclosed trailer - so just jumped up to HD and diesel motor.
Loved the truck - but was not the right tool for towing!
  • 6 months later...
I agree with TxTruckMan.
Old thread, but I thought I'd weigh in on the subject of tires and fuel economy.  There's a whole lot of misinformation out there on increased tire weight being the biggest factor for decreasing fuel economy.  It's in every forum I've seen.  Somebody puts a mud tire that's 30 lbs heavier 3" wider and 3" taller than the street tires that were on it, then proclaims that the weight is the culprit for the loss in fuel economy.  Nothing could be further misconstrued.
First, consider that a taller tire has a mechanical disadvantage in leverage to turn the tire.  It's the same thing as using a longer breaker bar to torque a fastener...in reverse.  If you apply force on a breaker bar, it will generate torque on the fastener.  Increase the length of the wrench and apply the same force and the torque on the fastener goes up.  Imagine the radius of the tire is the "wrench" length.  The larger the radius of the tire, the more torque on the axle it will take to move it.
Wider tires generate more resistance to rolling.  Aggressive tread cause more rolling resistance. Weight? that's a long way down the list of influence on fuel economy.
Edited by Spurshot
    • 100% agree, there are a lot of variables. I definitely do not drive I’ve like a grandpa but also don’t drive like I stole it. Truck is currently in the shop so I’ll have to get weight later. The price for driving it doesn’t bother me. My precious was a 6.2l so the cost between the two is a wash.
    • if you want a short turning radius get a short bed Colorado!
    • that is pretty awesome MPG there!  I think so far one observation is these trucks do way better on MPG under 65mph vs 70+ and they really suffer at 75+   I noticed on the stretches into NE on 76 and 80 which is posted 75MPH and I was doing 82 I was getting more like 13.
    • No ETA is available for that engine at the moment in the GM system.   I would start at the dealer.  Try and talk to the parts manager or service manager and see if they can start a CX Connect case and get an ETA from GM on when engines may be available.  If they just check Parts Workbench and say "no eta", they aren't trying hard enough.  They need to do a CX Connect and chat with DPAC to find the ETA.
    • I would have to read back to get a better picture in my mind of some of the other comments and what they were using for a driving scenario they based the fuel mileage off of. That is why the fuel mileage conversation is extremely difficult to make fair comparisons from. If I was to be living in town and only driving around town, light to light and some longer stretches that doesn't have a light every block, and the usual stop at a grocery store and the bank and so on and so forth, my fuel mileage even during the summer time would be so bad with my truck I don't even want to know how bad it would be !. Then add in winter time and idling to warm it up to clear the windows and driving through snowy streets etc, large heavy trucks with gas engines have NEVER been worth crap for fuel mileage and why some little pot licker of a car with wheelbarrow tires and a 1300 cc four cylinder non turbo engine was the ticket to using a mere fraction of the fuel over a full size pickup.    By the way my truck has the 34" tires as its a HC but not the BFG KO3 tires ( that was an option for my truck but the sales guy couldn't figure out what the tires actually were so that never got on the order until it was too late to change the truck order ). So what fuel mileage your getting actually sounds good for "town driving" and with my truck when I go to town the fuel mileage keeps increasing as I get closer to town because it takes quite a while to get the driveline oils warmed up ( and why it always shows better fuel mileage on the return trip from town because its already warmed up ) but once I am in town that fuel mileage average just keeps dropping the more I mess around town and then has to recover back to something reasonable again by the time I get home for an over all average.    I'd be curious what your sticker says for the factory weight of your truck, mine is close around that 7700 lb due to the options it has. But anyway the long and short is, vehicle weight, higher rolling resistance heavy tires and a hefty driveline and a relatively large gas engine make for crap fuel mileage in stop and go scenarios, all one can do is drive it easy off the line at each stop and as my dad had said over the years, drive like a raw egg is under your foot and that's the best one can do. Years back with a carbed engine and if the carb was getting a bit out of tune etc as would the ignition system, the fuel mileage on pickups with larger engines was just awful compared to what your getting. We pay the fuel price penalty for driving HD trucks over some little vehicle, that is the reality.
