Very excited to share this! BCM Programming, finally done!
Special thanks to WAMS - www.whiteautoandmedia.com
- Hyperflash Deleted
- Turn Signal Indicator Failure Deleted
- Remote Start increased to 20 Minutes
- Remote Start enables (for trucks that don’t bVe remote start)
- Fog Lights stay on with High Beams (and have FULL control)
- Fog Lights stay on with Intellibeam/Auto High Beam (if equipped)
- Tap to Pass (Turn Signal Activation) increased from 3 blinks to 4 blinks
- Key Fob - Front Windows Roll Down, Driver (and Passenger for SUVs) will Roll up on key fob lock
- Key Fob - All Windows Roll Down (for trucks not equipped)
- Heated Seat enable (for trucks that didn’t come equipped with heated seats)
- 98MPH Speed Limiter increased
  • Like 6
  • Thanks 2
Phil your the man are you making a express up harness for the passenger side ?
Phil your the man are you making a express up harness for the passenger side [emoji848]
Yes. Working on it.
  • Like 5
  • Thanks 1
So does this work with 2014? Do I get a new bcm or do i mail my bcm for the upgrade?
My last question, would this upgrade also allow me to use the keyless touch pad entry device that's available for 2016 models and up?
Sent from my Pixel 2 XL using Tapatalk
Curious, once those changes are made are they permanent?
What happens if I take my truck into the dealer and they do an “update” on the BCM? Does it retain the changes that WAM did?
Regards,
rog
You would mail your BCM in.
Keyless touchpad entry?
Regards,
rog
Generally, whatever is updated on the BCM usually only applies to what is updated. But I’ll defer to@GTPPrix for that.
Good question! So part of this service is to make sure you have the absolute latest updated available software and calibrations for your build. That being said K2 development has been frozen for some time so unless something REALLY big happens (like a recall for example) the chances in this are very very slim; you'd be more likely to have a BCM go bad and be replaced. I can honestly say this happens so infrequently its not even a statistic with the thousands of various modules out there that we service.
If something like that were to happen we would redo your unit on the house.
  • Like 3
20 hours ago, Rock1500 said:
Got it. What is the normal turn around?
I asked the same question he answered in this thread.
On 7/25/2019 at 5:04 PM, pgamboa said:
Yes. Working on it.
I never even knew I wanted this until now!
I always knew I wanted it, I just dont want to do the work hehehe
  • 5 years later...
When will it be available again??
    • Breaking News!    I'm going to tell you that I'm going to tell you.  Then I'm going to tell you what I'm going to tell you.  Then I'm going to tell you.  Then I'm going to tell you what I told  you.  Then I'm going to tell you what I'm about to tell you on the other side of the break.  Then we're going to break. Then I'm not going to tell you what I told you I was going to tell you.  But I'll tell you something else that is Breaking News just coming to the desk that everyone reported on yesterday.  Then I'll tease a human interest telling I'll get to on the other side of a larger break. Then I'll tell you one item in 20 seconds and go back to an even longer break. Longest break of the night.  Then I'll tell you a fluff piece that takes 10 seconds and sign off into a three minute break while you wait for the next 30 minutes of rinse and repeat on the local news.    In al you'll get about 12 minutes of something, 5 minutes of which is worth hearing in a 30 minute show and 18 minutes of advertising at a sound level twice as loud as the news.    Of course you can switch to cable news and hear 12 different people tell the same four stories in much the same format as the Network News for 20 hours of which the majority will be advertising.  And four hours of late night Specials about things you wonder why you stayed up to listen to. Half of which will be repeats.....   OR you can go for a drive
    • Did you ever figure this out? My 2022 Trail Boss, and now my 2026 LT did this from time to time.  I believe it was more connected to Android Auto and my phone being the cause. Maybe try going for a drive, sans cell phone.... and see if it happens?
    • I have a 2026 Silverado LT, the non bose as well.  Upgrading the door speakers is pretty straightforward. You could honestly go to walmart, or Auto Zone/ O Reilly and get a set of 6x9s for the front, and 6.5s for the rear. You do also have to get some adapters for each, but they are like $10 a pair on Amazon. Then some plug and play harnesses that are about $10 a pair on Amazon as well.  And I would also suggest a 10 pack of the Amazon Basics sound deadening. Slap that all around the speakers and on the open metal of the inside of the door. And your golden.   I am currently doing this with my Silverado. Although I am having a bit of trouble because I am snooby I guess and bought some Alpine S2 S69c's which are 2 way components and I am having to wire from the door up to the dash....  Having never installed speakers before, its taking me just a bit to get everything correct. But if you dont buy expensive component speakers, and just some $40-$50 door speakers. You will DRASTICALLY improve the sound over these stock paper cone junk speakers. I thought my Silverado had an issue with the radio/ sound for a while.  Come to find out.  The stock speakers are just THAT SH*TTY   I cannot wait to have some decent sound in the truck   What did you end up doing?
    • Its all automatic based on yaw sensor data.  If enough incline is detected, it engages.   My recommendation though would be to disengage it before driving off and not let it auto disengage by touching the gas pedal.  The HD trucks use the same setup as prior years, the drum in hat park brake.  But now with an electric actuator.  If you drive off repeatedly over time, it can torque the park brake shoes and can also prematurely wear them out.           Electric console shift will set the park brake on flat ground too.  Pretty sure they've got it programmed to activate every time.
    • Anyone install a a supercharger on your 6.6L L8T? Talk to me...
