2018 4x4 leveling
Cudda
2018 4x4 I want to level up front. I have a 3 inch difference from front tire well to back tire well. What size spacer should I use. Going on top of shocks. Thanks
I have 4x4 Z71, added the motofab 2" lower spacer lift in front.  By measurements, almost level front to rear but I want a little more rake so adding a 1" to the rear.
Side note:  Seems like extra steps needed to do the top spacer in order to accomplish the same thing.  Your call.
I originally used the RoughCountry 2” lower spacer to accomplish this. Just remember that you’ll need an alignment when done. If you look around on here you will find plenty of topics about this, and there and many different ways to accomplish what you want.
Yep. Thanks. As I further investigated putting top spacer is much more involved. Will go with rough country 2 inch lower spacer. And an alignment.
    Brandon 29
    Brandon 29
  • Who's Online   5 Members, 0 Anonymous, 347 Guests (See full list)
