2014 chevy Silverado Z71 Cam kit
I'm looking to put a performance cam kit on my Chevy, but I want to know what I should do to it before I put it on. So far I just got a cold air intake and exhaust system and what Cam Kit should I get and how much should I be paying?
Some people will tell you kooks or some other expensive brand, but i, and others,have had good luck with speed engineering long tubes, they were great on my 02 and ill be getting them again on my 14.
Sent from my Pixel 3 using Tapatalk
Yes 5.3 and no that's what i wanna know, i was thinking of short tubes.
Are you looking mid range to top end power or low to mid range. I say this because I have had short and long tube on the same truck. Went from short to long and lost on the low to mid but gained mid to top end and this was with tunes. I haul and tow frequently so torque and power down low are my best friend.
Be prepared to drop some cash on a cam kit for the truck, it's not as easy as it used to be.  I'd recommend Texas Speed for your cam needs, they have L83 specific cams designed for these motors.  You'll need a cam, valve springs, pushrods, lifters and trays, vvt limiter, crank bolt, and head gaskets to complete a cam swap.  You're looking at a little over $1k in parts only, and you'll have to pull the motor to install the cam due to the oil pickup tube bolt location.
Anyways I would look into Speed Engineering long tubes and a custom flex fuel tune to start with before digging into the Gev V cam world.
Good luck man.
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
