On 9/12/2019 at 2:16 PM, Wheelguy said:
If your clicking goes away in 4WD then I'd think it's the stub shaft issue.  Like I've mentioned in that jingle thread, I had a loaner that I felt was making the jingle sound & it wasn't what I would call a clicking sound at all (I did listen to your videos & that wasn't what I heard - you could hear the sound inside the cab with windows up).  The sound I heard sounded like tiny pebbles pinging around underneath.  Listen to that first movie where the guy used his hand to make the ping clinking sound & imagine that sped up 2000 times - was a bit high pitched & definitely stopped when pushing the 4WD button.
With that being said, I'm not qualified to say your issue is or isn't related to the stub shaft problem or what I heard was definitely the stub shaft noise.  Also, what you feel is a click might described as a ping or other sound to me or someone else.  Trying to communicate these sounds via words can be wishy washy at best, IMO.
What would be just completely ironic is if the heat shield & other stamping issues GM GPS is supposedly looking at right now ended up curing all these mysterious sounds that have been described in various ways. ?
I forgot to add to that bit of info in my post above that my chief sent the oil pcv PIP document to GM GPS because they'd never heard of any issues with the pcv making noises - yet there's a pip for a chirping noise coming from the engine (dated 10/2018 IIRC) & no fix due to a supposed engineering change being considered.  That make me just roll my eyes & shake my head.  Seems like no one at GM (at least among the powertrain folks) knows what's going on with strange noise concerns from customers - only what they've managed to find on their own after more than a year of building trucks and excluding their road test periods prior to production.  Test drivers must have been wearing earbuds all day....?
you get any news on this?
I have had a clanking noise under mine since new.  It is LOUD. It usually happens under heavy braking with a right hand turn.  Only happens once every couple weeks.  I know I would never get my service advisor to reproduce it.
Sorry, haven’t heard anything as of yet. I’ve been off on holiday/vacation since 12/19 & not returning until the 13th. Will talk to my engineering chief to see if anything has been discussed. I’m not going to hold my breath over much.
mine's been doing this as well for the past month or so on and off... unfortunately not often enough to bother taking it to the dealer to not be able to reproduce the issue. I had the 2WD jingle issue fixed a few months back, and that particular noise hasn't returned. My clicking noise mostly happens on braking, but occasionally when taking off and seems to be coming from the passenger side underneath the front, whereas the jingle issue in 2WD was clearly (on mine at least) from the drivers side of the vehicle.
thank you for checking in on it.
  • 5 months later...
2020 Sierra 1500 Denali left front wheel area clicking noise at 1000 miles. Brought it to the dealer and they also heard the noise. Same as posts above slow speed backing up and turning and also while braking you would hear clicking noise. Service rep explained the noise is due to a manufacturing problem when truck is made that the wheels of the larger rims are not torqued to correct specifications! He said the mechanic is re-torquing all the wheels to specifications that GMC require to fix this known problem. I’ll be listening to see if the noise returns. When I left dealership no noise heard.
  • 4 months later...
Hello everyone I’m Brett, i have never posted on this page before. But I have experienced the noises everyone’s explaining and believe it or not I had to have my driveshaft replaced. It was a loud clunk under the truck, as I would accelerate and brake. GMC fixes the problem without an issue. After 3-4 months I’ve noticed the noise again. I have a 2020 at4 carbon pro 6.2.
Hey all, new LT Trail Boss owner here and Im experiencing a similar click/clank sound during low speed breaking or starting from a stop. If I shift from R to N or from D to N the noise sounds nearly identical. I wanted to listen to the attached videos to see if this was the same issue but the vids are gone. Does anyone have these or can repost? Would be much appreciated
Edited by shouldveGotDiesel
so my 19 trail boss had some clunking going on in my front end for a few months now. finally got it to the shop and they said there was a bolt loose under a crossmember and that caused my front end to move around. they tightened it and said it was good to go. I asked if there would be some wear since you have a stationary part moving around and they said no it is good. went home and noticed it again. so back to the shop I go. they put in on the lift multiple times and finally my passenger balljoint just fell apart. the Axel shaft also pulled out and the boot is tore. I just went there to get stuff out of my truck I need since I won't have it for a bit. I should have took a picture. the ball joint had zero grease on it. the shaft you could see what pulled out. I asked since there was no grease on the passenger side, are they going to replace the driver side also. they said no. that blew my mind. this situation could have been very bad if it would have fell apart driving interstate speeds. so here I am driving around a tiny ass equinox and its deer hunting season. I told them I want a truck they said no. I told them I am taking this equinox hunting and plan on hauling a deer in it. nothing else was said.
anyways this is something I would have the service dept take a look at if you have some clunking noise from front end. it was noticeable driving slow and when making turns. especially if I went over little bumps in the road. also when I would take off from a stop I could hear it and feel it.
I am considering on calling corporate to tell them the situation and let them know I want the driver side replaced. if it falls apart and im in the middle of nowhere ice fishing or hunting and have no service, then what do I do. hopefully they understand. it would really suck if it fell apart when I driving 75-80 mph.
I have a 2500 with only the part time t case and have not experienced this in this truck. I would first look for a slip joint or a splined shaft in the driveline. Known noise issue on grand cherokee with the NP242 which has full time option. Some synthetic grease was the fix. Being gm didn't lube other chassis parts before leaving the factory, good chance something else got missed.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 1,016 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
