Will it Fit Guide:
These are all sizes that will fit our trucks stock or with the correct modifications listed next to the size.
I hope this becomes a useful tool for everyone. This is strictly a guide, not an end all be all. Full disclosure: there will be some variation between tire manufacturers, lift manufacturers etc.
This is a live tool I am constantly updating and need more information to continue growing it. I have mostly focused on stock size wheels, but would like this to eventually grow into a comprehensive chart for other configurations. If you have set ups not listed here (or is on here, but you have more information) that you think should be added let me know.
Please include all information for your setup.
Version 1.0
Pretty cool idea. I'll contribute, since I have 17's, which is less common.
285/75/17 will fit on the stock 17's, at stock height, with GM mudflaps, and no trimming. I ran those for nearly 5k miles, without any issues.
285/75/17 will fit on 17x9, +18mm, with 7 cranks on the stock keys (1.5"), without any trimming and GM mudflaps.
I too run 285/70/17 on stock rims with no rubbing. I started with the truck stock and have plenty of room....now how they keys turned up some and could clear much larger.
Thanks Big Whiskey. Your post on another thread is actually where I verified that the 285/75R17 would fit! I appreciate the info, I’ll add to it!
I should be pushing out a new update later today. Any other inputs, notes or corrections? This will be update v1.1. It should clarify some things as well
  • txab pinned this topic
I see you have info on 275 65 20 on a +15 offset wheel requires trimming of mud flaps. I have 275 65 20 on stock +44 wheels and they fit without trimming. I previously zip tied the fender liner a little tighter to the frame on both front fenders for my other wheel set up so I'm not sure if that was required or not for the 275 65 20 on stock wheels. I guess I will add my other set up is 275/60/20 on +18 wheels and they fit with no trimming either.
  • 4 months later...
  • 4 months later...
What is "bags on rear" on the chart for size 305/70/18? What does that mean? I have a 2018 2500hd 4wd. Will have a leveling kit. Want to keep stock wheels.
2015 GMC 2500hd cc 4wd 2in level, nothing trimmed and front flaps are still installed. Wheels are fuel sledge 18x9 +1. My last set of tires were 285/70/18 open country mt. They rubbed only at full turn, mainly for about the first 20k miles. I just installed a set of 285/70/18 ridge grapplers and they have plenty of clearance. After looking at the way the tread pattern is on them, I bet I could have fit 295/70/18 ridge grapplers. I'm bummed that I didn't try one of that size first. I had a set of those tires already waiting for when my new 18x9 +18 wheels showed up. I figured coming in 17mm would allow me one size larger. Long story short is that 5 sets of backordered wheels later, I gave up and just replaced my existing 285's on my existing wheels that were just going to be an extra set in my garage. I guess ridge grapplers must clear a little better for their size compared to the open country mt. Hope this helps the next guy questioning a similar fitment
