Good question, I am planning on installing a SiriusXM stratus 7 receiver and was wondering the same thing.
I found a place to tap into auxiliary 12VDC. Under the drivers side dash there is an extra connector X260. It has a blank mating connector pugged into it. I will be going to GM to see if I can get the pins.
In the GM up-fitters website you can download the breakout but the Black wire on 1 is ground and the Violet/Yellow wire on 6 is the accessory power. It is a 14 pin plug.
x260.doc
x260.doc
Thanks for the info. Going to use this tomorrow to hook up some additional USB Charging Ports.
Keep me posted on this. I would like to set up an additional USB charging port and keep it clean like a factory install. If you can post a write up or PM how you did it I would really appreciate it.
Did GM sell you the connector pins? If not where did you find them? Thanks
I have them on order from GMpartsdirect.com
Have not received them yet. Today I will swap the 50 amp fuse (F27/F28) in the passenger side fuse box so the accessory power will be tied to the retained accessory power and will try tapping into the extra pin near the F28.
Part number is listed in the attached word document. Two different pin sizes. Also swapping the fuse did not change the extra pin to RAP. So I wired the sirius power cord to the cigar lighter wires
Edited by RobZ
added content
If I am reading the word file right the terminals are 13575818 and 13575824? Just confirming because gmpartsdirect.com lists those numbers as "wire" and a little over $6 each.
Yes, they are the pin crimped to a 6" piece of wire with a butt connector, not cheap
  • 2 years later...
Does anyone know what fuse the violet/yellow wire is on?? I found the x260 connector yesterday, but pin 6 is not hot when the truck is running. I'm thinking it's a blown fuse.
    250.3k
    Head Scratcher
    Head Scratcher
  • Who's Online   1 Member, 0 Anonymous, 1,481 Guests (See full list)
