Tire Size Option HELP for 2" Leveling Kit for Z71 with Stock 18" Rims
Hello, looking for a little help here.  I have a 2018 Z71 Silverado Crew Cab with stock factory Goodyear Wranglers tires and rims.  I had a 2" Motofab leveling kit installed for ground clearance for the front air dam and to put a slightly larger tire on when the originals wear out.  After I installed the kit my factory tires began rubbing on the inner side wall against the upper control arm - I thought this was odd as I'm reading guys are running 275 and sometimes 285s on their trucks and the rubbing concern was more specific to the wheel well, not the control arm.  Factory tires are 265/70/18s.  I wanted to go to a 275/70/18 or maybe even a 275/75/18 but it seems like the tire is too wide as is.  No other changes/mods and the truck was aligned by the dealer after installation.
To alleviate the rubbing with the stock tires I added a 1/4" wheel spacers to the front (per Motofab's advice) and added masking tape to where the sidewall was contacting the control arm and the rubbing stopped - thankfully. The rubbing only occurred when in full lock on uneven ground before the spacers were added, after there hasn't been any sign on the tape. The spacer has worked but now I feel stuck with the 265 width and limited selection of taller tires (only ones I can find are 265/70/18 and there aren't a lot) and didn't know the wheel spacers would have been necessary.    I heard the tires may have soft sidewalls but I can't imagine this being too much of an issue.
Anyone have the same issues?  What are your running on stock rims? Ideas or help?
thanks in advance!
I had stock tires  (265/65/18) on 18" rims with a 2" motofab leveling kit under the strut on the lower control arm on my 2015 Z71.  I never experienced rubbing issues; however, I did have some issues with ball joints and cv joints when making tight turns while in 4wd. I switched last year to the bilstein leveling shocks and am now running Cooper Discover AT3 XLT (275/70/18). I still don't have any rubbing issues.  All that to say i don't have any issues going to a larger tire on a leveling kit.
Thank you for the info - did you need to program the truck for the larger tires for speedo and brakes?
I'm wondering if the control arms are the same on the 2018 as the 2015.
I have a buddy that has a 2013 regular cab short bed and he has a different control arm assembly.  Here is the kit I had installed, I realize there are different type of leveling kits.
Chevy/GMC Leveling Kits - Front Kits - 07-19 Chevy GMC Silverado / Sierra 1500 2.0" Front Leveling Lift Kit LM
I have 1/4" wheel spacers which work for the stock tires/wheels and was curious about going to 1/2 inch as a work around but am worried if there would be enough stud or if I could change to longer studs, any ideas??
Thanks in advance
275/70/18 Nitto G2's on American Racing wheels that have stock specs.No rubbing.
my 2017 had 20s on good year 275/55/20  20x9 from factory. im on moto metal 20x10 w 33x12.5s now but i did do a bds 4" lift . google tire calculator. its great help.. plug in ur stock size and wanted size an all the specs pop up.. i found it super helpful.. good luck..
Thanks Guys....yes nice truck, that's the look I'm going for jscottl.  I have the rig only Graphite Metallic - your tire and rims really change the appearance.  Sweet!!
Looks like you have a 2" level on the front as well??  Did you need to reset the speedo or program with the bigger tires?
The stock tires really stunk in the snow last year - they don't like the slushy snow so the ABS lets you keep on rolling....
The other reason I'm going through this is my last Silverado went through 2 air dams on hunting excursions - ouch....
Kit is Rough Country 2.5" front/1" rear.
https://www.roughcountry.com/gm-leveling-lift-kit-1305-10.html
I haven't touched the speedo. From what I can ell if it is off it's not by much.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
