28 minutes ago, Trailboss91 said:
Please send a pic and details of how you had it installed. Cant wait to see how it turns out!
Ill be doing it myself. Its done by glue and double sided tape. I will post pics after i do it
20 hours ago, Nola Sciko said:
I'm planning on getting the hood scoop next month.  Just got the air designs spoiler last week
Would you care to post some more pics of the spoiler and elaborate on how you installed it pretty please :)
For the install I cleaned the surface with alchohol  and the spoiler attaches with double sided tape. I had to trim a little bit to fit my roll n lock bed cover
Very nice! Thank you sir.
BMC Extreme Customs.
Part#: BMC-21026
Single Scoop Functional Ram Air Hood
Fully Integrated Ram Air channel internal to hood - no extra bolt on channels to buy
Fully Functional -interfaces through Open Path or Cold Air Intake
Uses stock mounting hardware - no need for new brackets or special struts.
Comes prebaked - which means less time for Prep. Comes ready for prep and paint
Highest quality available and built in the USA
Includes Fitment Guarantee 1 Year Warranty
I have not seen this one in person. But, the pictures look decent.
Edited by Darksky
No Hoods offered for the T1 trucks.
Picture of the underside.
Sorry, it’s all for us “old” truck guys.
FWIW- I do like the looks of this one.
Edited by Darksky
On 9/11/2019 at 9:37 PM, Tumtum5891 said:
Just ordered my airdesign scoop today. Pics next week after delivery and install
Any update on that air design scoop? I really like the look of it
Yup. I like it alot. Did it myself but a second set of hands would have been nice
    • Today I filled up with 4.899 gallons of fuel at a cost of $4.899 a gallon. $24 bucks. 290 miles. 59.2 mpg. After my 4% COSTCO discount just under eight cents a mile.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • Checked the pads today and there's plenty of meat on them. If the message keeps coming up, I'll just answer YES that the pads were replaced and wait for the squeal.
