I've spent some time on google and youtube looking for this answer, but apparently I'm the only one who experiences this issue.  My remote control and tpms arent working so I've purchased a new rcdlr from Chevrolet, but I cant seem to determine where it's located.  Someone mentioned previously it should be under the headliner?  Okay, that sucks, but lets get after it...but where?
Can someone point me to the correct location, a helpful how-to link or anything of the like?
Above headliner on rear crossbar above rear glass. Passenger side. No programming required.
remove interior panels and pull down on headliner?  have any information on ways to access without damaging other components in the process?  I'm decently mechanically inclined, just havent taken apart interior on this truck.  I would imagine two rear sail panels need to be removed and then hopefully headliner will be free enough to access.
I appreciate your response.
If memory serves you don't need to take both sides down. I think I just pulled the pass side panel and pull handle down. It's been about a year and a half so I could be wrong.
you are correct.  I pulled the upper panel on the passenger rearmost pillar.  I also removed the grab handle for safe measure.  Simply pull down on the headliner and there it was.  Replaced the unit, to no avail.  I still do not have remote control availability.  I'll look and see if there's an "at home" programming capability.  If not, I'll have the dealer figure this mess out when I take it in for power steering recall.
Thanks for your help
Some more info if it will help.
Remote Control Door Lock Receiver Programming and Setup
Diagnostic Aids
The remote control door lock receiver only functions as an antenna, receiving the signals sent by the keyless entry transmitter and forwarding them to the body control module (BCM). The keyless entry software is contained wholly within the BCM.
Replace and Program ECU or Reprogram ECU
This ECU does not require SPS programming or any setup procedures.
RCDLR.pdf
Edited by tbarn
took truck to dealer this morning.  Setup for power steering recall as well as try to get rcdlr working.  Attempting to program new rcdlr receiver/antenna module to no avail it was decided to also replace the BCM.  I made the judgement call to skip the diagnostics and replace the BCM.  This also did not work.  Will return to dealer at a later date to diag electical.  Tech checked fuses and all is well there so somewhere along the wiring we have an issue.  Not what I was hoping for.
Will update in the future when a determination is made.
I have a 2014 chevy with this same issue.  Been happening on and off for a couple of years.  Keyless entry works when it wants and the TPMS goes in and out every couple of months.
Any update on yours?
I have done some research on several websites of forums. At the bottom line, they all ended up with the dealers saying it got a “bad connection” somewhere a long the line, so I’m assuming that it’s got damage wires somewhere from the RDLCR to the BCM, I just haven’t figured out where it is actually damaged. I have checked  all the connections from the receiver up to the door sill front passenger and all was good, so somewhere up on the dashboard is what I’m thinking ?
Any update here? I’m having the exact same issues on my 2016
Any updates on a fix here?
I have an issue with my door locks too I have figured out it is only when it's around a certain vehicle it effects two different GM vehicles at my house so far there is no tpsm issues but the car effecting it does have a tpsm issue. Not sure if this helps but could give you something else to look at.
    ncleg
    ncleg
  • Who's Online   4 Members, 0 Anonymous, 693 Guests (See full list)
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • Yes your absolutely right, I been looking at the 4 inch BDS one and it acutely states you can use the stock 20’s just not the 17’s or 18’s, I also didn’t realize that with my 275/60r20 stock wheels I’m already running 33 inch diameter wheel setup lol so I can just run my stock wheels and tires atleast to start.
    • I would expect that to be lift-kit dependent.  If the kit has interference issues w stock wheels, then the kit/manufacturer should indicate that somewhere.
