2017 Sierra Infotainment system version
On a 2017 Does anyone know to tell what version is installed I know on the 2019 805 is the most current
When I update always says most current installed but I’m not convinced
Yes I know I can update but it has never downloaded an update since new always says I have most current version  I would like to know if the version build number is shown somewhere I can’t find it
On 9/16/2019 at 11:19 PM, HeySkippyDog said:
No, that was a question.
You can update it? I wasn't aware you could.
Sent from my SAMSUNG-SM-J727A using Tapatalk
Ah yes go into settings scroll thru you will find software update you must be connected to wifi for it to work  I enable my phone hotspot for the data wifi source
48 minutes ago, jay webb said:
with out knowing the RPO code and the vin i cant tell you.
the vin will allow me to look up RPOs via my gm global access
Here you go Jay. Appreciate any help on this
based on your vin this is all the RPO codes for your truck
Option Codes
*IVH is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
4GB - 4SA - PREFERRED EQUIPMENT GROUP PREFERRED EQUIPMENT GROUP
6FZ - 7FZ -
8X2 - 9X2 -
A31 - POWER WINDOWS A45 -
A48 - POWER SLIDING REAR WINDOW A68 -
A91 - REMOTE LOCKING TAILGATE AKO - DEEP TINT REAR GLASS
AL0 - AN3 - FULL FEATURE FRT BUCKET SEATS
AQQ - REMOTE KEYLESS ENTRY AU3 - POWER DOOR LOCKS
AXK - AY0 - SIDE-IMPACT AIRBAGS FOR DRIVER/RIGHT FRONT PASSENGER HEAD-CURTAIN AIRBAGS FOR ALL OUTBOARD SEATING POSITIONS
B1J - REAR WHEELHOUSE LINERS B30 - FLOOR CARPETING WITH FLOOR MATS
B86 - BODY SIDE MOULDINGS BTV - REMOTE VEHICLE START
BWN - REAR BUMPER CORNERSTEPS C49 - REAR WINDOW DEFOGGER
C5Z - GVWR: 3266 KG (7200 LB) CGN - SPRAY-ON BED LINER
CJ2 - AUTOMATIC CLIMATE CONTROL CTD - CARGO TIE DOWNS, UPPER (4)
D07 - D75 -
DD8 - AUTO-DIMMING ISRV MIRROR DH6 -
DL3 - POWER FOLDING OUTSIDE MIRRORS DNS -
DP6 - E2C -
E63 - PICKUP BOX FE9 -
FHO - G80 - AUTO. LOCKING REAR DIFFERENTIAL
GAT - ALL-TERRAIN PACKAGE GBA - ONYX BLACK
GU5 - REAR AXLE - 3.23 RATIO H2W - JET BLACK
I17 - ENGINEERING YEAR 2017 IO6 - INTELLILINK(TM) W/NAVIGATION
JD9 - JF4 - POWER ADJUSTABLE PEDALS
JHD - JL1 - TRAILER BRAKE CONTROLLER
K05 - ENGINE BLOCK HEATER K34 - CRUISE CONTROL
K47 - HIGH CAPACITY AIR CLEANER K4C - WIRELESS CHARGING
KA1 - HEATED FRONT SEATS KC4 -
KG4 - KI4 - 110V AC POWER OUTLET
KNP - TRANSMISSION FLUID COOLER KRV -
L86 - ECOTEC3 6.2L DI V8, VVT, AFM M5U - 8-SPEED AUTOMATIC TRANSMISSION
MBC - MSL -
N37 - TILT/TELESCOPING STRG COLUMN NE8 -
NKC - NP5 - LEATHER WRAPPED STEERING WHEEL
NQH - AUTOTRAC 2-SPEED TRANSFER CASE NT7 -
NZH - 20" ULTRA BRIGHT ALUMINUM WHLS NZZ - UNDERBODY SHIELD- TRANSFER CASE
PCM - SLT 'PREFERRED' PACKAGE PPA - 'EZ' LIFT & LOWER TAILGATE
R7K - R7W - MANDATORY VK3
R9Z - POMS SEQUENCING RC4 - SPARE TIRE
RC7 - P275/55R-20 ALL-TERRAIN TIRES RIA - ALL-WEATHER FLOOR LINERS (LPO-DEALER INSTALLED)
RUF - SAF - TIRE CARRIER LOCK
SLL - SLT -
T3U - LED FRONT FOG LAMPS T4F - HID HEADLAMPS
TDM - TEEN DRIVER TG5 - SINGLE-SLOT CD PLAYER
U19 - U2K - SIRIUSXM SATELLITE RADIO(TM). INCLUDES A 3-MONTH TRIAL.
U2L - U73 -
UD5 - FRONT & REAR PARK ASSIST UDD -
UE1 - ONSTAR TURN-BY-TURN NAVIGATION UF2 - LED CARGO BOX LIGHTING
UG1 - UNIVERSAL HOME REMOTE UJM - TIRE PRESSURE MONITOR
UK3 - STEERING WHEEL AUDIO CONTROLS UQA - BOSE(R) SPEAKER SYSTEM
UTJ - UVC - REAR VISION CAMERA
UVD - HEATED STEERING WHEEL V22 -
V76 - FRONT RECOVERY HOOKS (2) V8E -
VB5 - VHM -
VK3 - LICENSE PLATE BRACKET, FRONT VRK -
VT5 - VT7 -
VV4 - ONSTAR 4G LTE WI-FI HOTSPOT WMH - 2017 MODEL YEAR
XL7 - YE9 -
YM8 - LPO IDENTIFIER Z49 - CANADIAN BASE EQUIPMENT
Z71 - Z71 OFF-ROAD SUSPENSION PACKAGE Z82 - TRAILERING PACKAGE
Z88 -
ZY1 -
i highlighted the RPO for the infotainment system in bold
Ok Tks but how does this tell me what version of Intellilink software I have
Remind me what the 3 button push trick is , I think I did that Yes it shows software versions but not the infotainment system unless I missed something
Power, home, and menu simultaneously
Sent from my SM-G973U using Tapatalk
That’s it  Tks
i will try again but did not see the infotainment version in there
