window up and down message
Yankeefan1
On 9/13/2019 at 3:07 PM, Yankeefan1 said:
"Open then close driver window" message comes on every time i ope and close the drivers door what do you think it could be
I got this message when I was having some electrical issues (turned out to be a loosely installed electrical component related to the starter). The truck was throwing a code and they tightened everything down. The only time I've seen this message since is when I disconnect the negative terminal from the battery when doing electrical wiring for accessories. I'm told its part of the truck computer's start up process. I'm not a tech by any means, but have seen this message.
