im going to do this as soon as it cools off some, i was hoping the dealership would get them changed out if i complained enough. im taking my truck back to the dealership every oil change to complain about the leaf springs and this horrible 8psd transmission. other than those two hunks of chit i like my truck. i wish i would have ordered a 6.2 and 10 spd but ill run this one until its almost out of warranty and trade it in. maybe by then they will figure something out. I loved my 2008 Seirra Denali 270,000 trouble free miles, so im not ready to give up on GM yet because the other trucks are fugly compared to the GM trucks...yet
Good info.
Edited by rkj__
5 hours ago, truckguy82 said:
How did you install? Did you take apart the springs to install that or simply jack up the truck and shove it in there?
What I did was place a floor jack on the frame just in front of the rear wheel and jack the truck up. This will spread the leaves out.  Taking the wheel off will make it easy to slide your rubber pieces in between the leaves. I slid each piece of inner tube as far forward as I could. Folded the excess over and used a tie wrap to hold it in place. I bought the biggest inner tube they sell at walmart. Cut the valve out. Held the ends of the tube up in one hand and cut it in half. Then cut each half in two again so I wound up with 4 approximately equal parts.
  • 4 years later...
Bought a 1/8 inch recycled rubber sheet from Amazon for less than $3 and cut into strips as wide as the leaf springs. Slid into the gap and pried open the leaf to get the rubber strip closest to  connection to the other leaf.  Zip tied the strip to the spring and it was like a light switch.  No noise. No clunk.
and now its back.  I have heard others say u bolts and anchors?  The noise is always on angled or reverse in a turn.
  • 5 months later...
I have a 2016 2500. I had this same noise on articulation of the rear leaf springs, when i go into a parking lot or even backing out of my driveway. I had been fighting with my local dealer about this noise since 10k miles on it. i gave them the truck for 3 days so the manager could drive it around to hear the noise. Of course it rained all those days and the noise was nonexistent when they got wet. i happened to be driving bye the dealer on a dry day and it started making the noise. I immediately stopped in and took them for a drive. We never made it out of the parking lot. He had me pull it into the shop right onto the rack. They lifted it up to look under it. They next called the heaviest guy in the shop over to hang on the bumper and bounce. They found the noise.
They did some research and found a bulletin that told them to have the truck on a level rack and loosen every suspension part front and back and retorque everything by stock specs. The service manager said to do it but also order a whole new rear leaf spring kit (springs, shackles, and bolts). Those got replaced of course right after my warranty was up. Luckily i was chasing this noise way before it expired and had it documented so they were no charge.
So we move on almost 10k miles later and guess what.........the noise is back. I found out that the noise comes from the cheap square plastic isolator blocks that are in between the two upper leaves. The dealer sells them for over $200 not installed.
I did my own research and found a guy that sells a kit for $200? i believe. It is some 1/4 inch rubber with a hole drilled in it and a zip tie. I just happen to have a 1/4 inch thick horse stall padding in the bed of my truck for protection. I got an 8 foot piece from tractor supply for $7. I have a 6.5 foot bed. All i did was take the extra and cut strips the width of the spring. I lifted the truck up by the frame so the axle hung down separating the leaves, of course the tire and wheel were off. Took a pry bar and spread them a little more and put the padding from back part of the leaf where it curls over to down between the leaf coupling bracket. Did it on both the front and back of each side in the rear. Haven't heard a peep since and its been 30k miles since.
    • I agree with this assessment. As you know I’m testing longevity with vehicles for the first time. I have a few vehicles I passed to kids and grandkids. We’re all past 100K miles some approaching 170K. I’m the only one doing 5k oil changes. The rest whatever the minder says. I’m the only one doing frequent transmission service. My odyssey the trip vehicle at 200K will be finished as a trip vehicle. I recently changed to high mileage oil, Valvoline. I can’t get past the fact that all manufacturers want to claim long service life. I just don’t make sense that they would go with low weight oil for mileage. While sacrificing longevity.
    • There's absolutely a mountain of profit in catering to the "I do my own research" crowd, people who are certain they know better. And I don't mean there isn't data to support that 0w40 produces less wear product than 0w20 in an engine like the 3.0 Duramax, that only feeds them the assurance they need. Again, my whole thing with oil selection is, sure, 0w40 or 0w30 produces less wear product. Are we talking the difference between the engine lasting only 100k versus 200k? Or are we talking more like, if the engine will already go 350k on a good 0w20 regimen recommended by the OE, is using 0w40 going to get us to 355k, assuming we can even get the rest of the truck to last that long, meanwhile sacrificing the first 5y, 100k in powertrain warranty. The answer isn't easy, there are tradeoffs.   I willfully use 0w20 Dexos D for this reason, knowing that a 0w40 will produce slightly less wear. I don't believe the delta in wear product is meaningful over the lifetime of the engine, and I place much more importance on driving style and overall feeding and care of the engine as a whole. It's the mentality that someone can abstain from alcohol their whole life which is an amazing boost to health by itself, theoretically. But if they're sedentary, that lifestyle choice will most likely kill them young despite their other, concerted efforts. Maybe someone doesn't drink AND they are the perfect picture of health and activity AND they use 0w40 AND they treat their engine perfectly. If living until 130 years is the goal, sure, do that. But it's going to be a really old truck falling apart around a good engine for that last 30 years, without a doubt.   I watched Demonworks' other video on the 100k+ 3.0 Duramax that had dealer 0w20 changes on what appears to be OLM-prescribed intervals (8-10k).   The QR codes are still present and readable on the main bearings. That's how little wear it has.   That's not proof that anyone else should stick to 0w20, but it's confirmation, for me, that 0w20 is perfectly acceptable to use in these engines.
    • 1Based on independent testing of OE 0W-20 in the Peugeot TU3M Wear Test as required by the dexos1 Gen 2 specification.
    • oh ya that's good to know - I would rather use a gear than the brakes down a long hill.  I would not let cruise control take over on snow or towing a trailer for sure on hills anyway.     The other thing about the CO trip was that was all done above 6K feet for the most part, so that has to use more gas as the motor is down a good amount of power up there.   If I drove my 2016 Camaro with a very similar V8 to this 6.6 it would probably get about 23-24 on the fast run up to NE.  But the premium fuel premium is steep here in CO, so it would still only save about $40 in overall costs for the round-trip.  And you sure can't carry much gear in a convertible camaro!
    • Got part #s of what you ordered vs what you got?
