Bad alternator???
RBSilvy85
Some of you might remmber my post aboit a month ago with problems unlocking and locking my truck with my key fob. That has still been an off and on issue where i hit unlock it unlocks and it locks immediately back up. I also had a new battery I installed last Nov die back in June. Advance auto tested battery and deemed it bad so they gave me a new battery under warranty. Fast forward tonight im driving and I notice truck is idling rough and lights are dimming. I assume my alternator is actually goin back causing these problems I have had. Is there a sure fire way to test my alternator to see if it is failing?
If it is a bad alternator, at least those are easy to change out.
I would NOT buy one at an auto parts store, however. I would buy another AC Delco/GM alternator. I've been bit by the reman/Chinese parts too many times to bother with anything but OEM.
Sent from my SAMSUNG-SM-J727A using Tapatalk
No I've been there before. My 03 Dilverado alternator went bad around the this same mileage (60k) and I had reman put in but from the start it didn't seem right. I could feel it bog down when I braked but then would recover. It lasted maybe a year and then I had to replace it with a new Ac delco. I plan on buying a AC delco from rock auto if this one is bad.
Ya 60k is early. I’ve owned several GM trucks and they have gone out around 130k miles or so. I have an Escalade right now with the original alternator at 189k.
