Replacement Leaf Springs
i replace the leaf spring pads all the time in the rear leaf springs and fix the issue.
there is now a bulletin with an updated leaf spring insert that we are doing at the dealerships.
its not the springs themselves but the pads between the springs.
5 hours ago, Darksky said:
Jay, can you post a link or the bulletin?
18-NA-183: Squeak and/or Clunking Noise from Rear of Vehicle - (Aug 6, 2019)
Subject:  Squeak and/or Clunking Noise from Rear of Vehicle
Brand:
Model:
Model Year:
VIN:
Engine:
Transmission:
from
to
from
to
Chevrolet
Silverado 1500
2014
2018
All
All
Silverado LD
2019
2019
GMC
Sierra 1500
2014
2018
Sierra Limited
2019
2019
Involved Region or Country
North America and N.A.Export Markets
Condition 1
Some customers may comment about a squeaking and/or clunking noise coming from the rear of vehicle.
Condition 2
Some customers may comment about a squeaking noise coming from the rear of vehicle.
Cause 1
This condition may be caused by debris getting between the leaf springs and/or loose U-Bolts.
Cause 2
This condition may be caused by a faulty spring shackle.
Correction 1
To correct this condition, re-torque the U-bolts of the leaf spring assembly, and install new rear leaf spring inserts, following the procedure below.
Correction 2
To correct this condition, replace the rear shackle following the procedure below.
Service Procedure
Prior to performing this bulletin, follow the procedure for Noise Diagnosis - Rear Suspension in SI to determine the source of the noise. Jounce the rear of the vehicle utilizing J 39570 Chassis Ear or equivalent, to aid in locating the source of the noise.
If necessary, road test the vehicle.
Note: On the rearward side of the leaf spring, DO NOT trim/cut the new replacement insert.
  1. Raise the vehicle on a frame lift-type hoist. Refer to Lifting and Jacking the Vehicle, in SI.
  2. Inspect the rear leaf springs and shackles for damage.
    • If damage has been found, refer to Rear Spring Shackle Replacement or Leaf Spring Replacement (1500), in SI.
    • If damage has not been found, proceed to the next step.
  3. Support the rear axle independently to relieve the tension on the leaf springs.
    Object ID: 5084560Click here for detailed picture of the image.
    • If squeak noise is coming from the rear Spring Shackle (1) lower bolt area (3), jump ahead to step #11.
    • If the noise is coming from the leaf springs (2), proceed to the next step.
  4. Loosen the anchor plate U-bolts (1).
  5. Re-torque the anchor plate U-bolts (1). Refer to Fastener Specifications in SI.
  6. Repeat steps # 2 – 5 for the opposite side leaf spring.
  7. Install new Rear Leaf Spring Inserts using the following procedure:
    Caution: Do NOT damage the finish on Leaf Springs.
    Caution: Do NOT damage the surface of the new insert when trimming.
    1. On the forward side of the spring assembly, insert a plastic trim tool or plastic wedge in between the #1 and #2 leaf springs, to access the old insert.
    2. Push up on insert until it hits the bottom of the spring above it. Then use a suitable cutting tool to cut the stem off from the insert.
    3. Remove the top portion of the insert, and then remove the bottom portion of the remaining stem.
    4. Using a rag and degreaser, clean any dirt or grease from between the leaf springs at the insert location.
    5. Cut the stem of the new insert with a hacksaw or suitable cutting tool. Make sure to leave 6 mm (0.240 in) of the stem.
    6. Apply a small amount of RTV sealer around the remaining portion of the stem.
    7. Install the new insert into the leaf spring. Make sure the stem portion lines up with the slot in the spring. Remove the plastic trim tool or plastic wedge to close the spring and seat the new insert.
  8. On the rearward side of the spring assembly, insert a plastic trim tool or plastic wedge in between the #1 and #2 leaf springs to access the old insert.
    1. Remove the old insert.
    2. Using a rag and degreaser, clean any dirt or grease from between the leaf springs at the insert location.
    3. Install the new full insert into the leaf spring. Remove the plastic trim tool or plastic wedge to close the spring and seat the new insert.
  9. Repeat steps #7 and # 8 on the other side of the vehicle.
  10. Jump ahead to step # 12.
  11. Replace Rear Spring shackle (3). Refer to Rear Spring Shackle Replacement in SI.
  12. Lower the vehicle to the ground and test drive to verify the repair.
Parts Information
Causal Part
Description
Part Number
Qty
N/A
Rear Spring Shackle
84444786
2
Leaf Spring Insert
84730971
4
RTV Sealer
88864346 (in Canada, 88861418)
My 17 has 8,000 miles and making the noise. I notice it most when backing into the driveway. Will show this TSB to the dealer if they give me issues. Thanks!
Correction 2
If you clean out the springs real good and use AC Delco High temp grease at the pads you will not hear a squeak.  It's sucks to clean em out and guys who use the Truck like a Truck probably will need the new pads which are less abrasive.
it will come back. what we have been doing for a long time at my dealership is replacing the inserts with the round rubber inserts that are on the bottom spring and that has worked wonders. here recently GM came out with the updated insert and bulletin.
Jay, if I was too order  new leaf springs from GM now, would I have still have this problem later on? Or are they made different now. I’m thinking about just replacing them but I want too keep the factory height and ride in the rear. Also what do you guys charge too perform the tsb u listed?  Thanks for the help!
Jay, do you have a part number for those new style rubber pads. I might just try those if they are not too expensive.
if you scroll up in this thread i posted the bulletin. it has the part #s and how to do it. issue is with the strike going on , we at the dealerships cant get parts for anything.
replacing the entire springs isnt going to fix it. and that would be COSTLY
the old way we were doing it was about an 1 hr/ 1.5 hr labor
im sure the new is similar but dont quote me on that. im not sure the cost of the parts. if you need just the inserts or the shackles as well.
looking up times via warranty :
Rear Leaf Spring Insert Replacement and Re-Torque Bolts
1.0 hr
Includes: Drain and Fill Fuel
Base LABOR TIME: 0.7
Left with Z82 LABOR TIME: 2.8
Left without Z82 LABOR TIME: 2.0
Right with Z82 LABOR TIME:
1.4
now this is warranty time. customer pay time is typically warranty time x 40% not including diag. at my shop we charge 0.5 to 1.0 diag depending on the complaint/system.
    LCH14
    LCH14
  • Who's Online   6 Members, 0 Anonymous, 934 Guests (See full list)
    • Looking for help!   2019 GMC Sierra 1500 - 5.3l 4x4 8l90 61k miles - truck is in Arizona, was over 110 outside on Monday when this whole situation transpired. Never had any major issues with transmission until this point:   Truck sat outside my construction office for approx 1 hour idling before I realized, ran around the job site wrapping some things up for the day and then left. Went to get food and sat in the drive through for approx 30 minutes idling. As soon as I pull out of the drive through and onto the main road, rear tires lock up and feels like transmission fell out of the truck. Shifted to park, shut the truck off and tried again, same thing happened. Was able to reverse into parking lot (truck slammed into reverse). Let the truck sit turned off for 10 minutes before trying again, but it continued to happen. Towed truck back to my house. Highest the trans temps reached was 198.   Friday, after work I start looking into the situation. Truck sat in my driveway untouched all week. Truck is now driving like normal, transmission doesn’t get over 185 degrees when trying to heat it up. Got up to 60 multiples times with no issues, no issues accelerating, only down shifted hard into first one time at 185 degrees. Does anyone have any insight? Never through a code or a check engine light. Truck has never been used to tow either. No transmission services at this point.
    • Atlas won.   I know better, but I did it anyway. I took a compressed air line with a chuck and rubber tip and jammed it in the open EGR port. The port was clear as far as I could see, and as far as I could poke with a flexible wire, but that doesn't mean it's not clogged.   Compressed air blew back at me along with a cloud of black. Oops. I didn't have the rubber tip seated in there all the way. Jammed it up in there some more and squeezed the chuck. PSI was set to 120. Poof! It blew back at me again. Third time...pfffffttssssssspffffffsssfffffff, face full of carbon, and then, kind of a thud..and the air stopped spraying back at me. It was now exiting the exhaust with a low shhhhhh sound as it flowed through the pipe. Something broke free. I pressurized the port again, and air flowed.   Made my day.   Long story short on this problem, it's fixed. Something was really blocking the EGR passages down low, and compressed air blew it apart. I don't recommend this as who knows what debris was sent where. But it's allowed me to move forward, mentally, and onto the next problems I need to get this little S-Blazer going down the road properly again.
    • Your truck lowered, looks good. I'm happy with the stance on this. I may need the extra ground clearance given my location/situation.
    • With this new pan, do you still use the same procedure to check the level? Its a deeper pan and our trucks do not have a fill tube/dipstick. So fill till fluid runs out the check plug?
