Anyone else get a grinding noise from underneath when you have a quick stop and go situation (1-2 seconds on the brake) and it triggers the Auto Stop/Start?  Grinding noise happens when the engine starts up from the auto stop.  No gas.  Just lifting foot off the brakes and grind noise. Happened maybe 2-3 times.  Never happens if I stop longer, past 1-2 seconds.  That’s my transmission getting a shave, right?  Under 5000km on it.  5.3 8 speed.
Obviously, I will now be conscious and try to hold my brakes a bit longer if I see the Auto Stop kicked in.
Edited by SilveradoRST
No, I have never had that happen yet.
Don't wait too long to get that looked at...otherwise it might not start back up one day.
Edited by newdude
As newdude said, get it looked at. I'm wondering from the description if the starter isn't trying to engage while the flexplate still has some rotation.
After thinking more about what the sound sounds like, it sounds similar to when you hold the key (old school, not push button) in the ignition a bit too long after the car/truck has already started.
Thanks for the bulletin newdude.  And everyone who took their time to reply.
I will try and get it checked soon.
Depends upon the reading of the speedometer, i.e. if the speedometer reading is 0 mph for a two second stop or whether not fully stopped with the speedometer reading 1-2 mph. Under these circumstances I'll hear the noise, but not a grinding noise, of the starter motor disengaging from the flexplate. The s/s system is not like a conventional starter arrangement - the starter uses a split solenoid and the front part will engage the flexplate while the engine is still spinning at around 4 mph and below during a stop. If the brake pedal is released while it is engaging and the engine is still spinning above 0 rpm and partially stopped, you'll get a different noise than when the motor is restarted after it has reached 0 rpm when fully stopped. If looking for it I can hear that mechanical noise, but it is not like the grinding noise when trying to engage the starter motor on the older vehicles while the engine is still spinning (newer ECU controlled vehicles without s/s won't let you do something stupid like that anyway and will not engage the starter motor on a running engine. Operation of the starter motor split solenoid in a s/s system is described in many articles,e.g.
https://gm-techlink.com/?p=8493
If a true grinding noise, likely a problem with the split solenoid in the starter.
Edited by Thomcat
addnl comment
I did delete that as it was for the Turbo 4 cylinder.  So disregard that.
Hello, new poster here, I found this thread and have a similar thing with my 2020 Sierra AT4. Under hard braking as I get to 15 mph to zero, I have a really painful grinding sound. It's a deep grinding sound, not like metal-on-metal train car sounds. What is very odd is that (I think) it doesn't happen with Auto Stop/Start disabled... which makes no sense to me (I thought it was the brakes making the sound), but so far in my testing it seems to be the case. It's difficult to reproduce the problem though.
my truck does it every so often. its loud too. talked with dealer and they said nothing except for its weird. but they have not heard it. its a stipend go situation and I don't have time to just leave it with them to try to get it to repeat. that auto stop function is stupid and should be the other way around. if you want to use it then you hit the button to turn it on, not have it engaged every time you start your vehicle.
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
