On 2/26/2020 at 7:40 PM, Zach-91 said:
Only when going over large bumps like speed bumps and pulling in the driveway
Did you have a trailer hitch in? I thought mine was making noise till I realized that was the bugger making noise.
I have a 2020 and from day one I thought my spare tire was loose. Uneven terrain, taking a speed bump at an angle and especially backing out of an uneven driveway the clunking is worse and loud.
From digging around here and on other sites I found my issue was the leaf springs are slapping against one another in the spring pack, especially when they are being twisted. Dealers have packed the springs with grease which will work for awhile and once it gets dry the sound comes back. A member here had a how to to add heavy duty rubber as isolators between the springs.  I added the extra rubber between leafs and it did help muffle the sound but really never went away.
You get used to it once you realize there's not much you can do and it isn't doing anything bad.  Loading the truck with weight will also make the sound go away.  I usually do 200 lbs in the winter for traction and the extra weight doesn't allow the leafs to slap against one anther when they are being twisted.  I also just installed a set of Airlift airbags and that has also really tightened up my rear end even when theres no load.  Really improved the ride and quieted up the clunking to the point its basically gone. Still need to drive the truck more but the few test drives I did are like night and day.
Edited by Grey3liter4x4
crap is annoying. mine barely started doing it as of last month. i do seem to hear it more on a incline. at firsi was thinking brake pads were getting stuck. waiting to take it in for my appointment to see what dealer says.
  • 2 years later...
Old thread but my 2022 Silverado 3500 is doing this exact thing at 33k. Just started to do it a couple of months ago. Couldn't get it to do it for the dealer unfortunately but its definitely happening after coming to a dead stop and then taking off again. My old 4tunner did this bad and was fixed by greasing the slip yoke and u-joints. I can't find a single grease zero fitting under this 3500 however so I'm at a loss on how to grease things up...
Any of you guys that had this problem a couple of years ago find a solution?
We are sorry to see you are facing these challenges with your Silverado and would like to investigate further for you. Please send us an email to [email protected]. Be sure to include your Username and Forum name in the subject line with additional details. We look forward to your email.
  • 3 months later...
Could it be the hill start assist holding your brakes? You said it's worse on an incline. I notice my 2021 definitely does it as well, I was thinking either the hill start assist is engaging without it showing on the dash or possibly a slip yolk issue (from recent experience) I'm new here and just spitballing.
  • 9 months later...
Old thread, I know. My 2021 2500 has been doing this clunk from take off for a while now. Anybody find a resolution?
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
