I took matters into my own hands today and took it apart myself and made a video. I added grease to the intermediate shaft to fill in the slop on the 2 pieces now my steering is smooth like it supposed to be I know this wont last forever but its gotta last more than 2000 miles or until GM comes up with a fix.
GM must have had a pile of GMT800 ISS’s sitting around and decided to use them up. Can’t believe this issue is reoccurring! WTF!
Thanks for confirming and sharing your video. BTW, you didn’t mention this or show it in the video, but you need to be careful when removing the shaft so that the steering wheel does not spin freely. It could damage the airbag clock spring. I also noted this in the video comments.
Hey Everyone, was just searching around for this same problem and came upon this thread. I have a brand new 2020 Chevy 2500 Gas (had 80 miles on it when i got it). Steering didn't really fee correct from the beginning. I have had a 2016 Denali 1500, 2018 SLT 1500 and never experienced this before. So I took it in for steering wheel shake and what seemed to be an alignment issue on Nov 19th . They did the alignment, but it didn't really help all that much- seemed better but not much. When driving down the highway at 65 plus, the steering feels loose and sometime cocks the wheel left or right 1-2 degrees. I also notice the clunking when at low speeds when pulling out of my driveway and it only happens in the morning when its cold and at less that 15 mph. When doing a search I ran across this bulletin as well. So wondering if its related or not.  Its an official service bulletin from GM so i would suspect they are starting to investigate it. Hopefully they do something fast. Im not into buying expensive trucks that should work properly right out of the gate. At the price point, the damn thing should be just about flawless.
Steering Dither/Shake or Quick Steering Wheel Oscillation at Speeds of 80-129 km/h (50-80 mph)
 20-NA-192 1..2 (nhtsa.gov)
Bought a 2020 3500 HD GM Denali. The truck is used in a forestry buisness so lots of rough road driving. The steering literally sound like a loose bucket of bolts at slow speeds.  They first changed the column shaft with no luck and finally the whole steering column itself. Never changed a thing. Driving me crazy.  Would not know there is a problem if I stayed on the pavement. Seriously considering dumping it on a Ford.
thanks for posting that video.
the clicking I have is definitely coming from those little white bushings/collars in the firewall boot. I have to take that apart and grease those.
I think my ISS is starting to clunk as well
Great video, that's exactly the slack I am experiencing. I am surprised that GM F'd up such simple/common component.
I wonder if we can get lucky with a good shaft replacement, or if all replacements are faulty. It would be kind of unbelievable to think all HD's are experiencing this issue after 5k miles or so.
I have a 2020 AT4HD with this exact problem. I've taken it to the dealer and they've blown me off saying they don't see a problem and everything is "normal". I can make the noise and feel the knock with the steering wheel and I feel and hear it driving the 1/2 mile of dirt road to my house (5 to 10mph). It drives me nuts since I'm $90k into this truck. How do we get GM involved if the dealer is ignorant?
**Update** Just contacted GM and escalated. Will update after that conversation.
Edited by mcloop
On 11/3/2019 at 6:17 PM, STGS said:
Have a 2020 Chevrolet 3500 4wd.  Anybody else have the noisy steering column. Has a popping click sound when making slow speed turns.  Never hear it at highway speeds.  Always at slow speed maneuvers.  My 15 did it also but my 17 did not.  The one thing that my 15 and my 20 have in common is neither had the digital steering assist.  My 17 had the assist and didn't make the noise. Drives me crazy.
I have a 2020 Chev 2500hd with same issue. at 5000km they replaced steering shaft. Now at 6400km its back.
Sometimes at crawling speed i get a sound like a gear issue with the steering.
Unbelievable GM still has steering shaft issues. My 94 1500 silverado had intermediate steering shaft issues when I owned it and 26 years later and they still do.
I guarantee you a lot of people are experiencing it. Until they come out with a redesigned part it will continue to have issues
I’ve had my intermediate shaft replaced twice now as well. I saved myself a trip to the dealer today and took out the shaft and greased the hell out of it. I also put an  o ring over the gap on the shaft to keep the grease in. The noise and clunking has gone away for the time being. I’m going to wait for the upgraded part to come out.
Edited by Dnuts
Grease is temporary, the grease the dealers uses is tacky.
i went as far as drilling and tapping a hole and installing a grease zerk
i looked to see if Borgeson has a shaft available. Their shaft goes up to '19.
I looked at part numbers for the 2020 shaft and it looks like it is compatible with trucks back to '17??
I called Borgeson, and the guy who I talked to (less than helpful) said the shaft only goes up to '19. He didn't offer any reason as to why or if it would work on the 2020.
I think he was just reading what was on the computer in front of him. I got the impression he didn't have any idea ??‍♂️
Just a thought. You could order the early shaft from an auto parts store. Most would let you order it to look at and compare before buying it. Some may even be able to get the borgeson in and compare. If it doesn't match, they'll just ship it back to the warehouse.
  • 1 month later...
Has anyone had experience with the Borgeson shafts? Are they much more superior to the stock GM shafts?
I checked the GM part numbers 2019 compared to 2020. They are the same, so I could try the Borgeson.
    DaleB
    DaleB
  • Who's Online   6 Members, 0 Anonymous, 1,196 Guests (See full list)
    • Hi all - my current truck is a 2022.5 1500 High Country 3.0. I bought the truck used last year. After doing some digging, I noticed that my truck's software is stuck on the original build from 2022. I have no available software updates. I talked to my dealer about this and they recommended not trying to force an update since the 36,000 mile warranty is expired. This is a big bummer since there have been many major releases since that have fixed small issues and improved speed/usability.   For reference, the current software build number is: full_gminfo37_gb-user 10 W158E-W164.4.2-QIH22B-563.3 158 release-keys Has anyone had a similar experience? Should I just forget about it and move on, or try a different dealer?
    • Sure. Buy it for me 🤣
    • Using zip ties but 2-3 they snap due to sharp edges. Just using a shoestring. Last longer. 🤣
    • I ordered the Snap On...waiting for it to come in later this week or early next week.   New front cover, new crank seal and new balancer are on. Water pump, pulley, fan, hoses, and plastics reinstalled. I can move forward knowing all my timing marks are dead on and the front engine is hopefully sealed better than it was. Take 2 with the water pump...trying high temp thread sealer on the lower bolts.   Rebuilt injector and new-new regulator is in, it looks like new. Top intake reassembled and all the bits are reconnected and snugged down.   Thinking about knock sensors again, I located both of mine and, there's your problem, Francis... The driver's side one is broke, plastic is bashed in, part of the wire is bare, and it appears to have been damaged like that for a long time. I saw the wire but didn't think anything of it. The knock sensor might not be my pulled timing issue, but it sure looks suspect. It must still be conducting, otherwise I'd expect a CEL. But perhaps with its sacred crystal inside exposed, jilted and dirty, maybe it's sending mixed signals. So I'm waiting for one of those and a new pigtail to come in. Pass side sensor looks good, except for the spark plug wire resting on it (!). The plug wires are healthy so it shouldn't be causing an issue, but I separated them and added zip ties to nearby looms to keep everything well apart.   So, I'm down to installing a knock sensor AND, oh, replacing the exhaust and cat. I actually think that's going to be fairly easy, it's all bolt-together, all new stuff from Walker is laid out on the shop floor ready to go. Hopefully have this thing on the road again for the weekend.   My luck? It will still be leaking oil, coolant, pulled timing, intermittent CEL for running rich, or it probably won't run at all -- because that's how this project has gone.   I've never worked on a vehicle so ...hurt? ...cursed? in my life. Everything has been effed with SO HARD, but I think...knock on wood...I've managed to undo all the backyard stuff and we're almost reset back to "just" an 80k mile, 30 year old Blazer.
    • Yes. You need to check out that thing, and the hub further.
