YES!  I posted the video a few months ago of my clunking.
If it''s the same issue as mine, the intermediate shaft needs to be replaced. Had mine done 2 weeks ago, and it fixed it. It was less than a 2 hour job as well.
Your dealer should be aware of this fix. Good luck.
  • 1 month later...
I have a 2020 Sierra AT4 HD Diesel and it has 7,500 miles on it.  I just noticed the clunk today.  Has anyone had any luck getting the dealer to fix it?
  • 3 weeks later...
I had a "click" as well, after the third visit they ended up replacing the entire column. First they said it was some gear. When I brought it in they said they had a bulletin that says if they have to replace that, they need to replace the entire column so they ordered that next. It is finally gone though.
Can you help with the bulletin number or something to help identify the fix. Thanks
My 2020 denali duramax has a clicking rattle type noise when turning left. Also when turning down hill at slow speeds feels like vibration through the front end, it sounds like grinding.
Any help appreciated.
Finally, I am not alone with this problem. I just bought my 2020 Sierra Denali HD and the steering wheel was loose from day one. Additionally, there was an annoying rattle when I would go over humps like a driveway curb, while turning sharply at low speeds. They initially replaced the steering shaft and it helped with the loose steering wheel, but the annoying rattle was still there. Today they replaced the entire steering column and the rattle is still there and it’s just as bad. Three dealerships said they have never heard of this before and I was basically told today that I will just have to live with it until GM engineers a new solution for the steering column rattle. I’m losing my mind because I refuse to accept that answer, after buying a $100,000 truck less than two months ago. From researching it online, etc. some people have talked about the steering box being the problem in older models, so I’m reaching out to see if anyone else has a 2020 and had the entire steering column replaced? Was the rattle still there? Were you able to ever get it fixed? If so, what was the ultimate problem? Any help is greatly appreciated!!!
The rattle you are likely hearing is hydraulic.  It occurs at low speeds around 5 to 15 mph when hitting chatter bumps or larger bumps in parking lots.  I often get it driving into driveway when going from gravel to concrete pad.  The power steering cooler is actually rattling due to hydraulic pulses going through it.  There is not a fix for it.  Couple things you can try:  remove the radiator close out (piano keys) and you will see the brush cooler.  Loosen the bolts holding the cooler and make sure the cooler can move freely.  Retighten the bolts.  You can also look at your power steering pump and make sure the supply and return lines are not touching.  If they are, loosen one of the bolts and rotate the pipe.  Neither of these will 100% fix it.  You guys are as frustrated as me with this.
#iworkforGM
  • Thanks 2
  • Haha 1
Has anyone had luck with getting this repaired. Mine clicks and clunks at slow speeds regularly. Has a clunk from 11 o’clock to 2 o’clock... any more suggestions?
I’ve had my intermediate shaft replaced once at 6000km and now at 8500km its clunking again at low speeds. Definitely hoping for a recall or support from the aftermarket because man it’s annoying.
On 11/12/2019 at 10:35 PM, Babymac said:
I have an appt next Monday to have my steering column replaced. It has a clicking sound just off of center to the left to right.
Mine has the exact same issue. They are replacing some parts in my steering column. I am not exactly sure what needs replacing yet, but I will report back after the repair.
The noise occurs as the steering crosses center when you steer left and right.
I have a 2020 AT4 2500 Duramax that I have had for about 6 months. This issue started around 6k miles. At first I only noticed it in the mornings when temps were below 50 degrees F. The noise is a clicking noise when you move the steering wheel left to right or just off center at slow speeds. You can even do it in park just shimmying the steering wheel. When temps are warmer the clicking isn't as noticeable.
I finally took mine into the dealer yesterday and they claim "normal". Clearly not normal as it didn't do it the first 6k miles. Obviously GM doesn't know what is wrong yet, nor have a service bulletin to fix it.
I also had a second clunking noise randomly occurring at cold temps as well from somewhere underneath the cab. There is a service bulletin to loosen and retorque the rear leaf springs. The dealer did do this yesterday and that does appear to help with the clunking noise but nothing yet on the steering wheel clicking noise.
Love the new Duramax but coming from Tundra's I have already had more annoying issues in 8k miles than I ever did in my last two Tundra's over 10 years.
    TopBo
    TopBo
  • Who's Online   6 Members, 0 Anonymous, 987 Guests (See full list)
    • Can anyone explain why the oil pressure runs higher after the DFM is shut off?  just installed the Pulsar Lt.
    • Thanks!  I figured as such; GM and other manufacturers have used standard parts and harnesses across trim levels and such for decades.  I pulled the blank accessory cover off of my commuter van (a 2016 or so Chevy 15-passenger) years ago and found the plug for a USB outlet.  It wasn't connected to anything, though (I tried swapping in an outlet from another van).  I was a GM Tech years ago (late-90s) and was pretty familiar with my 2006.  I might be wrong, but I view newer vehicles (pretty much anything made in the past 20 years) as being a lot more plug and play.  Meaning, more unused wires and plugs unless you have the Mack Daddy of vehicles.
    • not all plugs will be used.  gm uses more generic harnesses that support most/all options, and if your truck doesn't have a specfiic option, the plug won't be used (commonly will have a dummy insert in the plug , or it'll be taped up, but some may just be left as is).  But it's sldo possible some p.o. has installed the wrong/cheaper parts that aren't correct for your vehicle...
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
