Finally got my rattle fixed. Took it in yesterday, and they said they couldn't hear it. I took 2 techs on ride and pointed it out multiple times. They took it back into the shop and proceeded to take a part the console and dash parts test driving several times and isolating the noise. Turns out it was a missing retainer in part of the ventilation system behind the dash. I picked it up today, and it's like a totally different vehicle, quiet at all speeds and road surfaces.
  • 10 months later...
I just got my new 2022 Silverado 3500HD with the 6.6L Gas motor. I have the clunking in the steering wheel since day one with 7 miles on the truck. You can only here it when going over rough ground/off-road. Normal highway driving you dont hear it. Took it to the dealer with 240 miles on the truck and 'they couldnt reproduce' the issue so they did nothing. I found this thread while they had it at the shop and i called them and told them to look at the upper intermediate steering shaft....They checked the entire front-end and the shaft and said everything was perfect and up to spec. They drove it multiple times and said they can find anything...
When i look up the latest part number in this thread, 84488136, it says it doesnt fit my truck. I looked at the part number of the shaft that is currently on the truck and its 85126059. I can hear/feel the clunking in the steering wheel. Any updates on the latest GM part?
  • 1 month later...
On 5/26/2021 at 1:25 PM, Rozz522 said:
Is anyone else having still seeing issues with a newer build 2021? I have a 2021 2500 SLE with a build date of mid-March and mine is like a constant road noise rattle from the steering column area. It isn't the clunk that others are talking about but more of a vibration rattle whether turning or going straight down the road, fairly smooth road or potholes I hear it from 5 MPH to about 45-50 MPH. It doesn't go away at 50 but is drowned out by wind/road noise. I looked under the dash and questioned whether it may be the e-brake cable or something else rattling against something else but it sounds higher. I'll try zip tying it out of the way a little to see if that helps, just wondering if anyone else is seeing the same thing.
I have a 2022 2500 LT gasser and i have this same issue from day one. It feels like something is rattling against the steering column.
Were you able to isolate it to the parking brake cable? I see someone else mentioned a "heater hose isolation fix" so wondering if that might be it too.
  • 2 years later...
Hello I’m having the same noise on my new Chevy suburban premier I went to the dealer and they told me they need to remove the entire dashboard I never did it because the noise is coming front the steering wheel column any one fix it.
    • You must have that upgraded gvw package which is only available or at least was in 2025 with the diesel engine for the 3/4 ton and that gave the truck physically the larger 12.0 ring gear rear diff and the 3500 rear spring pack. There is a difference in what the diff housing looks like externally as one tell tale and also your truck should have the upper overload spring pack and the frame pads that the pack goes up against.    The pressure the tpms system kicks the alarm in on a stock setting truck, that is a good question and was just from what I recall but I doubt I made any notes on it as I knew for the rear that it was not at all what I was after regardless either. Being that you have a diesel and if running on stock tires the minimum pressure on an empty truck seems to be around 50 psi from hearing of those that have weighted the front axle but the rear axle is very similar in weight to a gas truck and again a near empty truck on the rear could go down to 35 pounds at minimum. However the weigh scale is the proper way to know for sure as a guide.    As to changing the readings on the dash from metric to the US measuring system, oh yes that is done easily but what I was attempting to explain was that I can't pick and choose items I want to have in US and those I still want in the metric system at the same time as its either all or none. For example lets say you drove into Canada and switched your dash over to metric so your speedometer read in km an hour, well then your reading kilopascals on your tpms readout and your wife looks over and says what the hell is that saying in the tpms screen and you say "darned if I know, I think its Chinese" !
    • This is partly why I decided to have switched over to Amsoil SS as a way of hopefully preventing the buildup of the sludge/carbon on the pistons and clogging of the oil control rings and the carbon that would cause the compression rings to stick in their grooves as well as stay cleaner up top of the heads in the valve train in the first place, an oil that has tested better by third party testing over typical shelf oil and also doing my best to run relatively short OCI. However in saying that I don't think there is any way to easily prove the oil I was using prior allowed for a buildup at the OCI I was doing, nor in the other direction to make claims the Amsoil is keeping everything clean either. There really isn't a window into the engine is there to know anything for certain even if oil samples were taken for example that showed still healthy oil being dropped out of the oil pan other than engine tear downs that extensive and expensive testing of oils does to actually visually see what is really going on inside the engine. I wish there was some easy method of seeing what is going on but I don't happen to be aware of that if there is.
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
