Automatic bright lights
nfisherman
I have a 2019 Yukon Denali with the automatic bright lights feature. How do you turn this feature on/off? I can do it with some combination of moves of the turn signal lever, but it takes me a few tries. I have read the manual but the instructions aren’t clear. Thanks
Pull the signal stick 2 times towards yourself and the once forward and return to neutral position. An “A” will be illuminated on dash below tac. To turn it off any movement of stick forward or back will disable
2 ways,
First is as what Bob2C have said.
And the second, is to turn high beam for a few seconds and the return to low beam.
(For both ways, the feature will not work when fog lights are on)
2 ways,
(For both ways, the feature will not work when fog light is on)
Did not know about second way. That would be the much easier way. Thanks
