Anyone missing their RPO label?
Just checked the glove box for my 2019 Sierra AT4 and couldn't find the RPO label. Anyone else missing theirs or has GM hidden it somewhere else? It's not on the drivers side B pillar and there was a recall on my truck for a missing sticker related to the performance air intake...maybe they forgot the RPO?
The RPO codes aren’t actually printed on the label anymore, and it’s not in the glove box anymore either. It’s a QR code you have to scan on the driver’s B-pillar. Think it’s the same one that has the tire sizes and GVWR.
That said, I tried a few different QR reader apps and never got a complete list. Just email [email protected] with your VIN and get the build sheet. Much better.
There are actually two QR codes on the B pillar.
One about mid-way with the tire info.  That one won't give you RPO's.  The other one is down low on the pillar, close to the rocker panel.  That's the one you need to scan.
Went outside and took a quick picture of mine...
    Daniel422
    Daniel422
  • Who's Online   5 Members, 1 Anonymous, 1,836 Guests (See full list)
    • It is a company truck. Not under warranty. Both companies I’m involved with usually buy trucks that are discounted when looking. Except what the owners drive. Being retired and minority owner. I don’t drive a company truck. If they have the new GM gas engine it would be in a service truck.
    • Update!   Had the dealer look at the issue. First tech says no problem?? I said there was no voltage on the brake terminal on the 7 pin connector! He said he did not know what pin I was talking about. So they bring out a seasoned tech and I explain to him. He attaches a VOM and has me push the brake, and sees no voltage!!    Tom, the seasoned guy says lets go back to my service bay and look closer. We discover thru his on line system that the controller is a "smart controller" as it needs to detect a trailer connected before the brake voltage is allowed to the 7 pin connector!!! He also showed me a GM bulletin stating some trailers with LED lights have such low resistance the controller wont recognize them!!! I was thinking WTF, but thanked him for bringing me back into the service bay and explaining this all to me. He also plugged in a trailer simulator and it showed the brake controller was indeed working.   After my dealership visit I hooked up to an older camper with standard 1157 lights and the truck did connect and the electric brakes worked great!    Not to sure what I have to do with the equipment trailer with LED lights, I cant tow it with no brakes.   Why did something so simple for many years have to get so complicated!
    • Do find out as that would be interesting if they have been using any L8T engines or for that matter have been running any of the Ford gas 7.3 to see how they have been panning out.    I assume your nephews engine replacement was on his dime as the regular warranty would have long past unless he had some form of extended warranty that covered such events. That shows though and may depend on the year of the build that failures are occurring with the valve train well beyond the warranty distance and more than likely so will others have that sneak up on them.
    • I realize this is an old post and its probably been talked about since then on this forum and I may have mentioned it myself but the Chev multi flex tailgate on the HD trucks are all aluminum so there is that one item that I am aware of on a current GM HD truck that is aluminum but if its the standard tailgate then its still a steel unit as far as I am aware to current 2026 model year.
    • I am surprised it didn't pop back up some just in time for the end of school/summer holidays and July 4th time period. Here in Alberta it hit its low coming off the high back a week before the end of June or so and has been creeping back up some and would equate roughly to around 20 cents per gallon increase. Of course there are various factors and one is the games they typically play with wanting to capture that holiday vehicle movement but also our government directly causing our Canadian dollar to drop ( a polite way of explaining the real picture ) causing our prices to go up rather than continue down like it should have, and even though we are sitting on the crude.
