Z71 Rancho Quality
32 minutes ago, TXGREEK said:
If you want a stock ride then get the 4600’s, front 5100’s leveling shocks will bring your front end up approx 1.75”, change your ride quality and throw off your front angles a bit. 4600’s in the rear unless you add another 1” block height making it total 2” in rear and then you’ll get full potential from the 5100’s
Sent from Above
I wouldn't go higher than the 3rd ring from the bottom as I have read some saying it produced a harsh ride from the spring preload. I don't care about a lift. Plan on staying with the stock 18" tires. The 4600 was my first choice but a dealer recommended the 5100 as the 4600 would be a stiffer ride, according to him.  It's all subjective I guess.
Found a leveling thread. According to some, the valving on both 4600 and 5100 are the same. Different color and the 5100 is front adjustable as you stated.
  • Replies 62
Correct, one is for stock height and the other for lifted or leveled. Last bit of advice, if ever you’re thinking of adding taller or wider tires, be very careful, some folks on these forums are full of $h;+ and WILL lie claiming they don’t rub but later same people will be saying they get a slight rub only on full turn lmao, misery needs it’s company. Good luck and Merry Christmas! [emoji320][emoji319]
Sent from Above
I have 5100's and I went with the third ring. Per Bilstein it gives 1.26” (32mm) average lift. I didn't measure it. I'm running a 285/70/17 tire, which are a little bit bigger than the 20" tires it came with but not big enough to cause issues.
As far as 4600 vs 5100 goes. I've also read that they are valved the same. I don't have an apples to apples comparison, but I have a lifted Jeep with OME springs and 4600 shocks, and the truck with stock springs and 5100's. Between those two the Jeep is definitely softer. But that's not a good comparison. So beats the hell out of me, but that's the first I've heard anyone saying the 4600s are stiffer.
If you don't care about lifting the front there are other options besides Bilstein. I went with them because I wanted to lift the front some and didn't want to use spacers. I went with Bilsteins on the Jeep because I didn't want to spend twice the price on OME shocks which have mixed reviews on longevity.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
    • If I forget the phone in the truck, and forget the truck in the phone, and reconnect.  It works great for the day.  Truck sits overnight, and the next day is a no go.  It will connect Android Auto via usb cable, but not bluetooth.   Ive tried Everything in this thread so far, and nothing works for more than a day.   I think I might have to go to the dealer and have them flash the pcm.   thanks for all the suggestions guys. 👍
    • 2022 2500HD Crew Z71 Duramax single alternator.  Recently had the primary (water pump / fan) belt tensioner pulley bearing to fail while hundreds of miles from home of course the plastic pulley melted and belt shredded which took out some wiring. Found a replacement tensioner assembly and belt to continue now would like to find a replacement for just the pulley and bearing to have a spare assembly in case of a repeat, the rest of the tensioner is fine. Has anybody here found a correct replacement part for just the pulley and bearing? Any help is appreciated.
    • +1 for the 3.0   Perfect for 1500 pickup towing duties.   Perfect engine for a 1500 pickup period. Huge torque at stunningly low RPM makes it feel a lot lighter than it is. The fuel mileage is insane for a tall and heavy 1500... 30+ on the highway. Mid 20's around town.   It's probably not perfect if you bought a 6.2 for the braaaaaaapppppp V8 noises and wrapping it out to 6k. The LZ0 acts and sounds like a small turbo diesel and there's nothing you can do to make a small turbo diesel sound like a big one, and you can't make an inline diesel sound like a V8 diesel/big Duramax. It's a different driving experience altogether.   Drive one, I think you'll like it, though...
    • I'll bet your truck lost the bearings on a roller on 1 of the lifters, and now is wiping out a cam lobe.
