Going to install a motofab 2” leveling kit in the morning on my RST does anyone know the torque specs on everything you take lose? Ex. Upper ball joint, tie rod, and anything else?
Ready lift says 65lbs for the upper ball joint.  That’s all I had to take off to do mine from their instructions. If I had to do it over, I would have went ahead and took everything else loose to make it easier. It was a nightmare trying to pry on and line up the level bolts.
Edited by AD80
  • 2 years later...
Rwood1,
Did you ever get all of the torque specs you were looking for? I'm looking for the same... to do the same.
2020 1500 AT4
john
I posted them all at one point.  If you do a search you should be able to find them.
Edited by Gangly
30 seconds with the Search Engine:
For the sway bar link you have to hold the bolt stationary while you thread the nut down to the base of the bolt.  Once the threaded nut reaches the base of the bolt, you can tighten it down to its specified torque spec without having to hold the bolt as well.
Torque Specs for the Upper Control Arm Ball Joint
First:  26 ft/lbs
Second:  Additional 60-75 degrees (A little shy of a 1/4 turn of a wrench)
Strut Bolts
Upper:  43 ft/lbs
Lower:  37 ft/lbs
Sway Bar Link
74 ft/lbs
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
    • It has happened to me a few times. I carry a jumpstart-tire inflator with me.
