Found the perfect Cell Phone Mount
I had the Ram Mount cup holder but it annoyed the hell out of me because it sits so far back and let’s face it, takes up your spot for coffee in the morning. I found this clap on Amazon and I’m super happy with it and wanted to share.
Here is the link to buy https://www.amazon.com/dp/B00J2E9FVA?psc=1&ref=ppx_pop_dt_b_product_details
That looks awful.  And is pointless - you truck has Android Auto / CarPlay.  Hook in the USB cable and do everything from the dash.  Cell mounts are pointless in these trucks.  GM even gives you a spot to set your phone.
I prefer the magnetic mount I have, it sits right next to the touch screen..
https://www.amazon.com/Magnetic-WizGear-Universal-Swift-snap-Technology/dp/B0773F8S74/ref=sr_1_5?crid=QO99VR2QG0N1&keywords=cell+phone+holder+for+car+magnetic&qid=1574604274&sprefix=cell+phone+holder+for+car+mag%2Caps%2C152&sr=8-5
You can't do 'everything' from the dash.. Try entering a GPS destination while driving, locks you outta the keyboard, try looking more than a few albums back in your music app... Also you can't see the list of turn by turn directions on Waze or Google maps without looking at the hand set... I drive a lot and use GPS a ton, gotta have my phone in conjunction with the touch screen in the truck to work efficiently...
You can easily enter a destination while driving - just talk to Google assistant.  For music I use Sirius and Spotify (well, Sirius for Howard and Spotify for music).  Zero issues getting to what I need.  I do agree you can't see the turn-by-turn list but I don't really find that necessary.
If you know your exact destination sometimes talking to Waze or Google maps works but, not when you need to add multiple destinations or aren't exactly sure how the business you're looking for is entered in the system... I use apple music and it doesn't have very good functionality through the in truck interface.. Often I pull over but, don't put the truck in park to enter info and it's much quicker for me to type.. With what I do for a living I might enter 10 destinations a day so it's kind of a different than average application..
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
