10 hours ago, Ryno12 said:
It is backlit. I don’t think that the battery is meant to be replaceable. The whole unit has to be replaced once the battery dies. Although where there’s a will, there’s a way. I’m sure it could be done.
$145 for a one time use product? DANG!
Hopefully it's got some kind of nuclear reactor/dilithium crystals in it that'll last forever!
On 11/25/2019 at 2:32 PM, AT4 HD Ron said:
I have this.  I know you can lock the fob inside the truck with it, which is what I wanted.
Not sure about keeping the truck running and wasn't even aware that the truck would shut itself off after some time.  I never let mine just idle for any amount of time.
It is a neat little device.  Dealer had to program it to the truck, then yes it just double-stick tapes wherever you want it on the truck.  It does seem a bit cheap and fragile so I do wonder about how long it will last, but so far so good.
Reviving this post, I just had the dealership install the Keyless Entry Keypad (KEK). I would like to be able to lock my keys in the truck but the truck still recognizes the Key Fob in the truck and keeps the doors unlocked.
Is the ability for the truck to allow the key fob to be locked in the truck a dealer programmed option? I asked about it and the service manager said I would have to look up the procedure online and program it myself. I also wanted to enter my own code to unlock the KEK.
I'd appreciate any info you could provide.  My dealer's service center doesn't give me a "warm fuzzy feeling" when it comes to maintenance on my truck!
DC
You need a Faraday pouch for the Fob.  I take the key with me but I leave my Fob in the truck when bicycling and kayaking so the fob isn't lost or ruined if it gets wet.  The pouch prevents the Fob from communicating with the truck while the pouch is sealed. I have the key, so I can get back into the truck when I return.
https://www.amazon.com/Todoxi-Protector-Blocking-Security-Protection/dp/B082WGDRR5/ref=asc_df_B082WGDRR5/?tag=hyprod-20&linkCode=df0&hvadid=416694464775&hvpos=&hvnetw=g&hvrand=15386290623695121476&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9015854&hvtargid=pla-896807912066&psc=1&tag=&ref=&adgrpid=94693386675&hvpone=&hvptwo=&hvadid=416694464775&hvpos=&hvnetw=g&hvrand=15386290623695121476&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9015854&hvtargid=pla-896807912066
Edited by unit
  • 5 weeks later...
9 minutes ago, JoeRudy said:
Has anyone programmed this at home with out dealer assistance?
You need the dealer, there is no other way.
Yeah I just spoke to them. It wold have been good if they said that online when ordering. Thanks!
Bit of a Necrothread but does the Master code stop working after you program a personal code?  I just tried to set mine up, master code worked fine, so I tried setting a personal code.  I don't know if I didn't hit the buttons I thought I did (personally I think the split buttons 1/2, 3/4, etc. are easy to make a mistake on) but the code I thought I set does not work, and now neither does the master code.  Is this thing now just a brick?
    • 2023 GMC 3500 HD, SLE, 6.6L Gas, 4x4, 6 Spd Options:  SLE Convenience Package; Driver Alert Package 1; Spray on Bedliner; X31 Off Road Package; TRAILERING MIRRORS, HEATED POWER -ADJUSTABLE, AUTO DIMMING, WITH TURN INDICATORS WHEELHOUSE LINERS, REAR INC. REAR AXLE - 3.73 RATIO INC. GVWR, 11,350 LBS. (5148 KG) INC. FRONT AND REAR PARK ASSIST, INC. ULTRASONIC     I have been launching my new boat and noticed some things related to the parking brake.. I usually set the parking brake (habit) when on flat ground for typical driving.    When backed down on the launch ramp to launch the boat and I place gear selector into Park, the parking brake activates automatically. My second nature is to set parking brake manually and noticed I was turing the parking brake off.  The parking brake appears to be setting itself automatically.   I looked all over my owner's manual and only found references to being on an incline and manually setting parking brake, or at times parking brake will be auto engaged, but nothing specific to my situation.    When is the parking brake automatically engaged?  Under what specific circumstances?  Can the auto set parameters be changed?     I like the auto set feature.  It would be nice if always engaged when shifted into Park and released when shifted out of Park (like my wifes 2025 RAV4).   Thanks!
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
