200 GMC Jimmy. No crank
Patrick Duster
Starting at the battery,  check voltage.  Remove both cables, ground cable first, inspect and clean both ends of both cables. You didn't mention it, but, have you tried boosting it?
Why did you change ignition switch?  That is an odd spot to throw parts in the hopes it is broken.
  • txab changed the title to 200 GMC Jimmy. No crank
