Nitto Ridge Grapplers, 16K miles, sipes have all but disappeared!
TXGREEK
Nitto Ridge Grapplers are WAY OVERRATED!
Anyone else experience their Ridge Grapplers wear so quick within 16K miles? I know tire wear is normal but aren’t the sipes there to help grip in wet conditions?? They’re also getting louder too.
Tires at 3-5K miles
Same tires at 16k miles!
Notice the same sipes have drastically shortened in length, no wonder I’ve been sliding on wet, rainy days. $400 tires.
Wonder if the General X3’s really do have deeper sipes and more silica as advertised....
Sent from Above
  • Replies 76
I have about 15k on mine and I was thinking the same thing. They are significantly worse in the rain now. Also I think they are a lot harder and we’re causing my rear end to jump around on road bumps. The bilstein 5100 helped but I’m thinking the tires definitely made it worse
Hey thanks for bringing this up. These would of been my next set. Everyone raves about these. Its good to have "real world' experience
Sent from my LG-G710 using Tapatalk
Tires at 3-5K miles
Sent from Above
Im glad you posted this. I have been debating getting these. I have ruled out duratracs because they don't have full depth sipes. I didnt realize the ridge grapplers didn't have them. I guess I will get terra grappler G2. Makes my choice a bit easier!
Sent from my SM-G950U using Tapatalk
It’s absolutely retarded, makes you wonder about each and every tire review out there. Tire reviews on Tire Rack and other retailers test “NEW” tires, not the wear and reliability as time and mileage adds on.
I’ve heard really great things about the General Grabber X3’s, they’ve got highest rated amounts of silica in their tires along with full sipes going down their lugs, just something to think about.
Sent from Above
Same here. I was able to squeeze 40K miles out of mine and was not impressed. I could have ran them for another 3-5k but they are terrible in the rain. Will be going with Mickey Thompson for my next set.
Of course they aren't gonna hold up. Look at the tread pattern!
Sent from my SM-J810F using Tapatalk
There’s plenty of lug depth but the length of the sipping exits have disappeared. I’ve been looking at the Open Country AT’s but being the Nitto and Toyo are sister companies, I’ll pass on both of them.
Sent from Above
Plenty of depth left, they’re fine on normal concrete surfaces when wet, it’s just the wet black top that’ll scare the Jeebies out of you lol! I did notice a while back while driving in a wet parking lot, my tires spun easily over wet paint strips.
Sent from Above
Sent from Above
Ive seen some bad reviews on the grabbers in wet conditions.ugh
Also saw some out-of-round conditions that weren't too good
Ok, I brought up the General Grabber tires and my tire guy gasped, he said NO! Didn’t recommend anything General due to issues. Being that I couldn’t keep worrying about driving in the next rainy day, just ordered new KO2’s, going from 295/60/20’s to a 285/60/20 for a slight better ride, ha! hopefully.
Sent from Above
Bro... Your like... the guinea pig. Could you try something else other than those Ko2s?
I’m stating away from anything and everything Nitto and Toyo. Staying away from MT Tires. What do you recommend???
Sent from Above
Sent from Above
Atturo trail blades look cool! Not sure about performance tho..
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
