'19 Chevy Suburban - Headlight Upgrade Help
MAG00
We just purchased the 2019 Chevrolet Suburban LT RST Edition. I believe it has the Intellibeam headlights, and I am not sure but I think they are HID. I was wondering if you tell me a good option if I wanted to upgrade to LED. The "bright white" or "cool white" is just easier for me to see with at night. Could you give me specific input on LEDs for our 2019 Chevy Suburban (i.e. specific products)? LED headlights, Fogs, Tail lights, etc. Would appreciate your input and guidance.  It has the TQ5-Headlamps, Intellibeam option, so what would be involved or needed?
My understanding is that the intellibeam is just a sensor up at the windshield that communicates with the truck CPM on what to do with the lights. Are the bulbs different? In other words if the bulbs are H11 low and 9005 for high, would swapping in LED bulbs hurt anything?
  • 1 month later...
There are many youtube videos that give a lot of information for headlight upgrades, so since I have not done it personally I cannot comment.  The only bulbs I have replaced are my license plate light bulbs since I had some of those tiny LED bulbs on hand.
Intellilamps mainly refers to the ability to your vehicle having automatic high beams as well as automatic headlights and marker lights.
If your headlights are on and your push your high beam stalk forward twice, you should have activated automatic high beams, as will be indicated by an illuminated green headlight icon with an "A" in it on your dashboard's gauge cluster.
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
