Water stain
Deus13
I have a 16 Sierra, Crew Cab with a sun roof and after a hard rain unnoticed the headliner against the back of the truck has a water stain on it. Does anyone know where it could be leaking from?
I would say, either your 3rd brake light, or you have clogged drains on the sunroof.
Is it wet anywhere around the sunroof itself?
A dude I work with has a 16 silvy and said he had to take his in for this. They replaced the 3rd brake light and some modified gasket. Not sure if it was a TSB or what?
Sent from my SM-N975U using Tapatalk
I didn’t notice any moisture around the sun roof. The sun roof is loud while driving so maybe the seal is bad, I can hear some air movement while driving
Can you hear the noise when it is closed, or in the tilt position?
As bas as it sounds, no moisture around the sunroof is a good thing, which could have been a bad "Sharkfin" antenna, bad seal on the glass, windshield, and so on.
I would take a garden hose and soak the back of the truck (third brake light, rear window), just to see if it looks like it is getting wet.
If you can do the leg work for the dealer, you might be able to get it fixed quicker, because these leaks will not go away by themselves.
3rd brake light leak is what mine was. I removed mine, cleaned the surface up real good and put it back together with some sealant on the stock gasket. Haven't noticed it being wet again and I've gone through many storms and 50+ touchless car washes.
You probably would not have. Most modern vehicles with factory sun roofs have drain tubes that run from the corners of the sunroof down to the pillars. If one drain is leaking it is possible to have water getting in in different areas.
What kind of sealant did you use? And will something like Oxyclean and a shop rag get the stain off the headliner?
I have a 2015 Silverado High Country with a leaking sun roof. The dealer tested and said it was the 3rd tail light. Replaced with the GMOE light and a bead of silicone.  The light does not leak.  Next day a steady rain and the passenger side headliner is soaked again.  A $55K vehicle should not leak.  This is my 5th GM truck but the first with a sun roof. My retirement present to myself, but this leak is a pain.  Both the dealer tech and myself checked the drains and no blockage.  Next week back to a different chevy dealer and the GM Rep.
Any ideas on a fix?
Willie
I have a '13 with a sunroof. after a couple of years my fastening hardware became slightly loose on the passenger side. I really didn't notice any leaks, however I did notice that the glass was not seating correctly on the seal. The glass was slightly higher than the roof. When I looked for an adjustment is when I noticed one of the screws had loosened. Once I tightened it after making sure the glass sat right, I haven't had a problem. but I do keep an eye on it. I also make sure to open it fully and clean the seal on a regular basis. I also lubricate the seal with silicone spray and a rag, not to mention making sure the drains are kept clear and in working order. There is also a Sunroof motor/actuator teach/relearn procedure that the dealer can perform after all adjustments have been verified.
I cleaned off the gasket, dries off the headliner, got all the moister out of the 3rd brake light and set a nice clean bead of bath tub silicone around the gasket. It’s still raining so if I wake up with a wet headliner then I guess it’s the sun roof drainage tubes
Where are these drains at? I’m sure they are close to the same spot on a 16 as a 13
Correct, but if the Shark fin is leaking he would see the stains from the water, or like my 14 be able to feel the water by touching it.
I would think so, two drain out by the front fenders, rear two drain out behind the doors at back of cab.
When you open the sunroof fully and look from above, you should see what looks like a plastic tray, stretching across the front. There are holes in the front corners aprox. 1/4 inch diameter. the rear drains are harder to see. but you can usually make them out using a flashlight. I usually take a bottle of water and slowly pour a little water in the trays and make sure the water is flowing out.
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
