MBRP vs Carven catback help
jankymechanic
I hadn’t heard of the dB until recently. Thought CORSA only had the $1,000 kits. According to the email CORSA sent me, the dB is designed more for trucks, has a slightly more aggressive sound than the sport, the muffler and tip are 304 stainless, pipes are a mix of 409 stainless, and it uses the u clamps instead of the torca clamps.
4 hours ago, DenaliX14 said:
I purchased the Corsa Sport exhaust system. It was ridiculously loud for me. Before swapping to a 7.0 I had the 6.2L. Drone was not bad but the exhaust note made me feel like I was killing small animals as I rode around.
I ended up keeping the Piping, cut out the muffler and used a Flowmaster pro series 3.5" in/out slip style. I was very happy with the purchase. Aggressive at WOT, rumble at idle and sounded great revving and zero drone. Here is the video of a cold start with the pro series. The temp is approximately 30 degrees F.
Do you still have the corsa muffler?
Would like to get their kit if they made one for the 6.2
I just bought the mbrp xp system for the 6.2l it had good reviews and then i found it on amazon for 80 dollars cheaper than anywhere else
Sent from my SM-G975U1 using Tapatalk
Never heard that exhaust in person. I kinda have my eye on the corsa. Ever since I first got a corsa exhaust on my CTS-V in 09 I was sold on them. Only downfall is the price really.
8 hours ago, DenaliX14 said:
No I don’t. I sold it a few months ago.
Damn!  Story of my life. A day late or a dollar short. In this case a few months late
You can purchase the muffler by itself. If you’re looking for bargain prices try the for sale forums. I see a lot of them in there.
    • 2026 3500HD.  Mostly empty. Grocery getter. What tire pressure are you running for 37x12.50x20. I have 37x12.50R20 Toyo Open  Country RT pro and been running around 55 lbs front and rear and it's too much. Tires are wearing more in the middle. Toyo says 45 front and 50 rear. Chalk test and it's still too much. I lowered it to 40 front 44 rear see what happens.
    • Enjoy the new truck, it’s a beauty. I’m glad you’re keeping the OBS, I love those old trucks.
    • With large equipment or deep mud it is more of a use the higher gear to avoid spinning tires, getting stuck because of spinning tires and doing damage to your machine. The idea is if you run out of torque before you spin tires you can still downshift for more torque. If you are just spinning your tires in the lowest available gear you are stuck and things break.   Automatic transmissions, traction control and electronic transfer cases change the calculation a little as you the driver have less control over each piece.
    • are there any codes? with lots of rust, perhaps disconnect/clean both sides of the connection/examine cable ends (the wires) for corrosion going into the sheath & replace if necessary/reconnect ALL the power AND ground cables between the battery, engine, frame, cab, fuse box and starter charm.li (website) has a no-start diagnostic procedure you can work through to get it working.
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
