Audio upgrade update.
I ordered the subwoofer with the separate amp for the door speakers.
I figured since I'm doing this I might as well make it LOUD.
Got my door speakers in two days from Crutchfield. I want to give them five stars . Lightning fast free delivery . ( Unheard of this month).
Free wiring adapters and mounting brackets. Pretty good deal I think.
Now I forgot to get some sound deadening for the door speakers so I am on the hunt for that now. The subwoofer should be here in a couple days.
I talked a buddy into letting me use his heated shop for the install probably the week between Christmas and new years. Hopefully I can knock this out in a day.42a31f3386ab2112cfdec704f95a55d7.jpg
Sent from my Pixel 3 using Tapatalk
Another audio upgrade update...
I ordered a pair of dash speakers also. I decided they may be a weak link so they are gone too.
Not a lot of choices because they are an oddball size (2 3/4") so I settled on some Kenwood KFC X2C . They are best sellers at Crutchfield and they had good reviews so I ordered them.
I also ordered some sound deadening.
All of the sudden, this got out of hand.
I was going to just throw a powered subwoofer on it and call it a day. Now it's a major job I'm just hoping I can finish in a day. 921fa6d17205211ee471b8b03a40921d.jpg
Got the Longhorn Fab Shop traction bars installed today.
Pretty easy had to grind a bracket down a little.
They work as advertised. It's a whole new feel, solid as a rock.
They look good too.672ff503278bdc20d5839f4efb1ccbab.jpg2d7d1f0cea48538796facaaf6091ffcf.jpg
  • Like 3
My wheel spacers are coming!
  • Haha 1
Rear Wheel spacers are here.
Stahl 1" steel ( not aluminum like Bora)
Bora and Stahl Spacers are made by the same outfit,
Motorsports Tech.
These are stout. They are not breaking. 10.9 bolts. The machining is precision.
I'm glad I got these instead of the aluminum BORA spacers.
So now I have to get them installed and it's snowing again.
I'll probably put them on when I install the subwoofer and all the speakers in my buddy's shop.be42f8ba3555f4b23409aaf95f544309.jpg
  • Like 4
Spacers installed.
Before and after pictures.
I hate winter BTW.
I can back my truck in the garage as far as the back of the cab and pin up a couple blankets and crank up the heat it's not too bad .
I'll take some pics when I go to the carwash later. It closes at 10. I found that if I go there at 9:45 I have the place to myself, it's about 55°-60° and I can stay as long as I want. Doors locked going in but not out.
The bs I have to put with in the winter to have a clean truck.
Tommorow I have to take the wheels back off and retorque the spacers then they are permanent.
My buddy with the nice heated shop has the covid. So I won't be able to use his shop for at least a few weeks. So I made my own heated garage. We used to do this all the time on job sites so they could pour concrete.
It's about 25° outside but under the plastic it's around 60°-65°. Good enough.
I'll be out here all night . Hopefully rockin by midnight5524bfce9444760cd988a65853301a43.jpg07b74d18f3dfc3b59df47f9daf6cd295.jpg
I'm sure my neighbors think I'm on drugs[emoji3166]
  • Haha 1
Sometimes you just gotta improvise. My first house had a door that was only 8 ft wide by about 74” tall. I could only pull in up to the truck doors or back in to the cab. When I bought my current house my priority was a nice garage.
Here's a shot with the spacers on the reare4a3a863e650e40f5e3a34f98be15c97.jpg
Morning Jim:
Love your garage extension.
Does the wider track width have a practical or engineering principal or is it purely aesthetics?
Thanks,
I got the Kicker subwoofer and the new speakers installed this weekend.
GM Kicker setup with 200 watt amp for the sub and 200 watt amp for the door speakers. Kicker CS series 6"x9" and 6.75" door speakers.
Kenwood Excelon 2.75" dash speakers.
Hushmat and wave breaker sound deadening was used.
Sounds pretty good. Not earth shattering but way better than a GM bose setup in a Denali or High Country. It was a good little project to start the new year.e873c2103f05f8ee6712d04fe6af49b8.jpg914569ba40f00f2ca7f54243cf5db8cb.jpgc1a3a42d8e58a7f9ec2a2fbefa24c426.jpg
  • 3 weeks later...
On 12/30/2020 at 4:28 PM, dieselfan1 said:
Spacers installed.
I hate winter BTW.
I never realized I wanted spacers until now! Looks great brother!
  • Haha 1
    whenindoubtuseahammer
  • Who's Online   3 Members, 0 Anonymous, 281 Guests (See full list)
    • Enjoy the new truck, it’s a beauty. I’m glad you’re keeping the OBS, I love those old trucks.
    • With large equipment or deep mud it is more of a use the higher gear to avoid spinning tires, getting stuck because of spinning tires and doing damage to your machine. The idea is if you run out of torque before you spin tires you can still downshift for more torque. If you are just spinning your tires in the lowest available gear you are stuck and things break.   Automatic transmissions, traction control and electronic transfer cases change the calculation a little as you the driver have less control over each piece.
    • are there any codes? with lots of rust, perhaps disconnect/clean both sides of the connection/examine cable ends (the wires) for corrosion going into the sheath & replace if necessary/reconnect ALL the power AND ground cables between the battery, engine, frame, cab, fuse box and starter charm.li (website) has a no-start diagnostic procedure you can work through to get it working.
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
