smoother ride
I have a 2014 Silverado.  Ever since new, I feel every little bump on the road.  Just purchased new Michelin tires.  Still no improvement.  What can I do to get smooth ride.  I have risen in F 150 and they are smooth as glass.  What is the deal.
Thanks for any recommendations.
Even though short, "davester" is on the right track.
Can you give us more detail...... Single, Double, Crew Cab? 1500, 2500? 18", 20", 22" wheels?
Load ratings on Tires can play a part, as well as tire pressure.  There are so many things that will provide tiny bits of relief that may add up to enough to be satisfied with the ride.
One more thing about the pick-up.  I am just short of 50,000 on it.  So the shocks should not be worn out.  But this has really been going on since day one of buying it.
10 hours ago, David Roark said:
Sorry for the late reply.  I have a crew cab, 1500 Silverado.  The wheels are 20"
Thanks.
Z71, LTZ, max tow package, 4x4?
On 1/9/2020 at 8:36 PM, David Roark said:
Just a regular 2 wheel drive LT
What Z RPO codes do you have on your sticker in the glove box.
If you have Z82 towing package, or the Z85 firm ride, you do have a stiffer rear suspension set up for towing or handling package.
What are you running for air pressure in your tires/what type did you buy? Not brand, but load rating.
I have the stiff towing package.  I purchased Michelin Defender LTX MS  275/55/R20. I try to keep them at 32PSI.
On 1/9/2020 at 9:38 PM, David Roark said:
Also, my average gas mileage has gone from high 19 to about mid14.
Any suggestions for improvement ?
Winter blend of gas is known to reduce fuel economy 2-5 MPG in some cases.  But with a 2014 and a direct injection engine, you're due for a good engine cleaning.  BG44k in the gas tank a few times a year, in addition to running top tier fuel, and the next time you have an oil change, run this for about 10 min in the engine crankcase before you change the oil.  These DI engines can really benefit from it.  Lots of carbon build up.
https://www.bgprod.com/catalog/engine/bg-epr-engine-performance-restoration/
Thanks for the BG44K suggestion. I have gone to their web site to read on the product and am on my way to get truck serviced.  Thank you.
The worst kind of advice possible. It sounds like you know what you’re talking about but you don’t.
The carbon buildup is in the intake path, particularly around the intake valves, because DI no longer has fuel being sprayed into the intake path which caused the valves and intake ports to clean themselves.
So what do you recommended to this guy
-a fuel based cleaner to solve the carbon buildup that is only there because the fuel never touches the effected areas.
-top tier fuel? Again
-and you recommended an oil additive cleaner as well?
Hopefully the guy sees this and does not waste his time and money on that crap
I saw your comment and paused before I purchased BG or MOC that many dealers sell.
So I need a fuel based cleaner and a oil additive cleaner.  Is that right?  And do you recommend a particular brand or brands?  The last I used and was brought up on was STP.
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed. Why not updates as well, especially since some of those can be safety related also?
    • That's good to know, but I don't think I'll even be running them under 45 in the rear  unless it's on the sand or something but will only be for a short distance anyways!    I didn't read all the instructions in the booklet yet, but do you know let's say I set the rear psi on the placard to 45, will the warning light come on soon as it drops under 45 or is there a percentage it has to drop from the set value before the warning light is triggered?
    • That's bad.  Like, its probably destroying the stub axle the CV slides into.   Do you have a proper lift installed with differential lowering brackets?  Did you install AT4/Trail Boss factory CV axles?
    • Hot? New Jersey? Today? I was working on my old 2000 Silverado 1500 today. Believe me, it was boiling hot today. As it has been.
