bulldog77 Posted January 13, 2020 Posted January 13, 2020 I cleaned the throttle body today on my 2016 Sierra 5.3 and then I intended to clean the idle air control valve but no matter where I look I cannot locate it. I even looked the part up on line but cannot find anything like it anywhere near the throttle body. The only thing that resembles it is an electrical sensor but it only has one bolt in it, the air control valve is supposed to have two. I hate asking stupid questions but if anyone can explain where this thing is I would really appreciate it. Thanks
CamGTP Posted January 13, 2020 Posted January 13, 2020 There isn't one. It's a drive by wire throttle body. The idle airflow is control by the throttle blade, which is control by a airflow/torque request within the computer.
flyingfool Posted January 27, 2020 Posted January 27, 2020 idle is also controlled mostly by the ignition timing for tighter idle control
TJay74 Posted February 3, 2020 Posted February 3, 2020 The above are correct, there hasnt been a IAC since the LS series engines came out. When the throttle blade is shut there is a gap there, that is the minimum throttle opening. That is what determines the idle function along with the ECM opening the the throttle blade to fine control it based on load from the AC system.
CamGTP Posted February 3, 2020 Posted February 3, 2020 1998-2002's LS1 camaro/firebird, 1999-2002 trucks with cable throttle bodies had IAC's as well as the 2004 GTO with a cable throttle body. And don't forget the express/savanna vans with IAC's all the way up to 2004ish. Gotta be fact based here lol.
