Can radio be upgraded? 2020 Elevation
I just bought a 2020 elevation and this stupid radio does not have XM. I thought I could deal with streaming through my phone but it's sucks! Just wondering if I'm able to upgrade the radio to accommodate XM radio. I can't understand why they wouldn't just have that it. Thanks.
You can get one of those in car receivers that are out there but no go no upfitting the factory equipment.
XM on SLE and Elevation is included only in the Preferred Package, RPO code PDQ.  Its standard on SLT, AT4 and Denali.
It can be added. You may need to swap out the shark fin antenna and upgrade to the IOU radio from infotainment.com
Thanks. I was hoping on just an upgraded stock radio and not a separate xm reciever.
  • 1 month later...
I’ve got a 19 High Country and I’ve currently got a 2020 RST loaner, I like the new options on the infotainment screen and album art display. I wonder if the system is just a plug and play swap if I could find one in a junkyard?
I downloaded the XM app. I have no complaints. I do prefer the pandora app though. I do want to upgrade my sound quality. Definitely need some more lows in my 2020 Elevation.
Yeah I like some the apps because the music pics up where you left off (sometimes) but you can't scroll through your channels without touching the screen and navigating through the app and you lose service if your phone won't connect and I have had to switch to radio cause it took so long. (I live in the Mts ) I just want to have my presets and use the wheel controls. Infotainment.com seem to have an upgrade for the system just got to call them and confirm. But def the speakers could use a bit more...
Idk on the 19’s-20’s the older gm vehicles you just had to buy the module and upgrade the antenna.
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
