It looks like I am dripping transmission fluid from the transfers case at the drain plug.    I ordered a new plug and will drain and refill with new Dextron VI.  When I install the new drain plug, should I coat the outer threads with black permatex?  Will this make it very difficult to remove the plug should I need to in the future?
Thanks,
First, are you absolutely sure the drain plug is leaking, not that fluid is coming from further up.
Second, with the drain plug out, after all the fluid is out, really clean the area and check if the housing is cracked, say, from someone overtightening the drain plug.
Third, check the case to see if it has a hole where the "gm pump rub" problem rubs a hole in the case.
Fourth, I would suggest not putting permatex on it.  Just get a torque wrench and use it to torque it down to 15 ft/lbs (that's from my '04 sierra full-service manual).
Fifth, the proper fluid for it is DexIII.  Find some that says it is DexII.  DexVI was known to cause leaks when put in older vehicles (particularly, made prior to when DexVI became a specification), as the seals weren't designed for it.  Even in '06, the transmission was specced to get DexVI, but the transfer case still was supposed to be filled with DexIII.
Owner's manual does call for Dex VI.  I'll have do take another look, but there wasn't any obvious fluid leaking down from above the plug.  This is on a 2012 sierra.
Oh, I was looking at the truck at the bottom of your post...  Forget the thing about pump rub and DexIII, and the torque for the drain plug may be different for your transfer case.
You gotta use thread sealer on that plug.  Its white stuff in small white tube made by permatex.  It isnt any kind of loctite.
Just be sure to work the stuff around in the tube before you use it.  You know how mustard always dumps water on your hotdog before mustard comes out?  This stuff kind of does the same.  So, I always squirt a little on a towel before I use it.
Looks like the housing is cracked.   I was able to see the crack after putting the new drain plug in.  I drained the fluid, cleaned it with  brake parts cleaner and sanded the area around the crack.  I put on some JB weld and holding out hope that this will seal it.
It looks like a new housing is about $250 on rockauto.com.  ACDELCO 19302452 GM Original Equipment .  Any idea what I'm looking at to get this fixed?
Part image
Sorry, no idea.  I know for the previous generation truck (GMT800's), it's
-remove the transfer case (the case to transmission bolts SUCK, particularly the one at the very top)
-remove the VSS sensor
-unclip a retaining clip for the rear bearing
-remove all the bolts around the edge,
-then the housing splits (takes some careful prying to get rear half off the alignment pins)
-clean off all the old sealant between the case halves
-put free sealant (anaerobic flange sealant) around the inside edge of one half (enough, but not too much, as the excess that squeezes out on the inside winds up trying to plug the inlet screen to the oil pump)
-put the case halves together, on the alignment pins and torque them down (I do it in 2 passes, first time snug, then second time torqued down to the right value, in a criss-cross pattern)
-put the retaining clip on the rear bearing
-reinstall the VSS sensor
-install tc into vehicle and fill
Removal/installation, you really want a second person to help, even with something like a transmission jack to lift it, as it doesn't have a nice flat lifting surface and it has to be rotated in 2 directions to get past the crossmember just behind the TC.
Yours is different, in that it has those two visible machined sections where something bolts onto, and perhaps there's more stuff to bolt on to the inside.  As well, there are likely bushings, seals and bearings you will have to install in that cover before it can be installed, that you will also have to buy, as typically you will fatally damage them trying to get them out of the old case half.
You might find youtube video's on how to do this job, and maybe study online parts diagrams for the transfer case, as you've identified the specific transfer case you have (hopefully!).  Most like, info about your TC is less commonly available than it is for mine, as the GMT800 TC's had the pump-rub problem, so it was pretty commonplace to remove them, do a pump rub fix that involved splitting the TC, and then reinstall them.  Later trucks didn't have that problem, so people only dealt with the TC when they failed.
Finally, going forward, find out what torque value to use for the drain and fill plugs, so the new case doesn't crack again...
Kenneth, did the JB Weld solve your cracked housing problem?
I have the same crack from a tech over tightening the drain bolt on the transfer case.
    • Conditions for Meeting a Cold Start   The ignition voltage is between 10 and 15 V. The barometric pressure (BARO) is more than 75 kPa. The engine coolant temperature (ECT) at start-up is less than 42°C (108°F). The intake air temperature (IAT) is between 2–32°C (36–90°F). The engine is OFF for greater than 6 hours or the following conditions must be met: The start-up IAT minus start-up ECT are within 12°C (22°F). The start-up ECT minus start-up IAT are within 50°C (90°F). Fuel level is between 25 and 75 %.   Circuit/System Verification Verify that all I/M System Status indicators report YES, and that no I/M Test DTCs are present.If any I/M Test DTCs are set Refer to Diagnostic Trouble Code (DTC) List - Vehicle. If no I/M Test DTCs are set All OK. Inspection/Maintenance (I/M) System Set Procedure   Warning: Refer to Road Test Warning. Note: Do NOT touch the accelerator pedal until told to do so. A change in TP Sensor angle or an increase in engine speed may invalidate this portion of the test.   Note: An I/M Test DTC will not be stored or erased from the ECU except at the end of trip processing, which occurs 5 s after ignition OFF.   Ensure that the vehicle meets the conditions for a cold start listed above. If the EVAP I/M System Status indicator displays NO, perform the EVAP Service bay test if applicable. Turn OFF all of the accessories; HVAC system, other electrical loads, including aftermarket/add-on equipment, etc., and open the hood.   Set the vehicle parking brake and ensure the vehicle is in park for automatic transmission or neutral for manual transmission.   Start and idle the engine for 2 min.   Close the hood, release the parking brake and Accelerate at part throttle to 72–80 km/h (45–50 mph) with this speed maintained until the engine reaches operating temperature, 8–10 min.   Continue operation under these conditions for an additional 6 min.   Accelerate at part throttle to 90 km/h (55 mph) with this speed maintained for 2 min.   Release the accelerator pedal for at least 10 s. This will allow the vehicle to enter the decel fuel cut off.   Safely stop the vehicle, with the engine in drive for automatic or neutral with the clutch pedal depressed and parking brake applied for manual. Allow the vehicle to idle for 2 min.   Shift the vehicle to park for automatic and neutral for manual. Turn OFF the ignition and exit the vehicle. Do NOT disturb the vehicle for 45 min.   Observe the Inspection/Maintenance (I/M) System Status with a scan tool. All of the I/M System Status indicators should display YES.   If the EVAP I/M System Status indicator displays NO, turn OFF the ignition, ensure that the vehicle meets the conditions for a cold start, and repeat steps 6-11 three more times, or until the EVAP I/M System Status indicator transitions to YES. If the indicator continues to display NO, refer to the Inspection/Maintenance (I/M) System DTC Table to identify the DTCs that did not run.   If any of the I/M System Status indicators display NO, refer to the Inspection/Maintenance (I/M) System DTC Table for the indicator which did not display YES. The I/M System DTC Table identifies the DTCs associated with each I/M System Status Indicator.   Observe the I/M Test DTC information with a scan tool. Verify there are no I/M Test DTCs present. If an I/M Test DTC is set, diagnose the DTC using the Diagnostic Trouble Code (DTC) List - Vehicle and refer to Inspection/Maintenance System Check.   Observe the engine DTC information with a scan tool. Verify no DTCs are present. If a DTC is set, diagnose using the Diagnostic Trouble Code (DTC) List - Vehicle. After repairs, perform the Inspection/Maintenance Complete System Set Procedure to verify no further DTCs are set.       Looks like one procedure to me.  Repeated as necessary.
    • My 2020 AT4 6.2 has had the valve spring issue addressed at ~200 miles, front cover/pump replaced at 18k, water pump at 34k and idler pully at 65k.  I would agree with ditching by 100k unless you elect to go with upgraded hardware...say built 10l80 and an lt4 or l8p swap.
    • I also need one of your modules for my 1993 chevy c2500 7.4 Thanks! My email is [email protected]
    • Chevy needs to do a black regular cab short box SS model with the new 6.6L.  400SS.
    • You might find the drive cycle you need somewhere on charm.li (website), otherwise I suggest a subscription to alldata.com to get them for your truck.
