Check engine light question
I recently installed some headers and my truck and after install the check engine light came on for catalytic converters sensor. So my question is if anyone has a fix to making the sensor “read” correctly like a resistor or something? I reset it with my flashpaq hand held turner but it reappeared the next day. I plan to do a full tune on the future so I’m just looking for a temp fix so that I can use the remote start. Ever since light came on it won’t let me use remote start. Any suggestions/experience is appreciated!
Maybe a wide band 02 sensor not sure though I’m looking to do headers and Y pipe in the spring. I’m already boosted and tuned only thing left is that. What headers did you get.
American racing
Forgive my ignorance but what is a wide ban 02 sensor?
Did not know myself, now I do:
A wideband oxygen sensor (commonly referred to as a wideband O2 sensor) is a sensor that measures the ratio of oxygen to fuel vapor in the exhaust exiting an engine. The measured ratio is expressed as parts of oxygen to fuel.
Perhaps describe what codes you are getting?
Just putting on headers shouldn't cause an problem with O2 sensor readings/levels, assuming the sensor is still in the exhaust stream and properly connected.
But, since you just installed them, you may wish to inspect the exhaust system for any leaks, as they can cause reading problems with O2 sensors.
I will pull the code tonight again. I’m new to this so I was just assuming that it was because of the headers not because of a leak. I had a friend who works for gm do it so I guess I just trusted it was done correctly
Did the headers come with cats?
If not, a tune is a must. Otherwise the light will never go off until the rear o2 sensor codes are disabled and the 2 different cat parameters in the calibration disabled.
To expand on the wideband part, it's a tuning tool. GM runs narrowband sensors on these engines, they only do two things. They read lean and rich of what I will call a target, that being roughly ~450mv. That middle spot on the 0-1000mv range is stoich. It gathers the information from the o2 sensor and spits that out into the fuel trim data that will show lean or rich values in a percentage. And it only does this in closed loop fuel control. Open loop or wide open throttle disregards o2 sensors and runs purely on the airflow/fueling data in the calibration.
This is why a wideband o2 sensor is required for tuning, it will tell you real time air fuel ratio's or Lambda (whichever way you wish to say it). Narrowbands can't tell you what a wideband can.
No cats with it. Tune sounds like my best bet. Do you have a wide band you recommend?
My preference is the AEM wideband with built in OBD2 port that allows for tuning with HP Tuners.
There are others out there that work but I haven't tried them. The AEM's work great and because I use HP Tuners, it makes it a breeze for data logging on 2007+ trucks/car.
Just curious were you able to remove the stock Y pipe in one piece. Just curious for a future mod thanks.
Yeah, it's easy just takes more time if you are doing it on the ground.
Remove all the nuts/bolts from the y-pipe to the exhaust manifolds, unplug all your o2 sensors, loosen the clamp bolt at the rear of the y-pipe. I'd use 1-2 nuts to hold the y-pipe up at the manifold connections for the time being.
Then put a jack under the transfer case with a block of wood to hold the transmission/t-case up. Remove the transmission mount bolt(s) from the cross member, then remove all 4 cross member bolts holding it to the frame. Remove the cross member and now you can snake the y-pipe out in one piece. I've done this many times, it's not that hard even laying on my back.
  • 3 weeks later...
This is the code it’s giving. Also bank 1. You think the spacer trick would work for now? I really want my remote start back until I tune later
    Whit.the.COB
    Whit.the.COB
  • Who's Online   4 Members, 0 Anonymous, 366 Guests (See full list)
    • Even tougher is the 5.0 / 302. That's what this one has.    https://postimg.cc/Z9XRrCSg   https://postimg.cc/4n3F3yzY   Just realized I had the airbox removed in the engine pic, lol.
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
