On 2/18/2020 at 8:54 AM, hkyfsh said:
Just an FYI.  I ordered this camera.  I talked to their customer service and they said this will complete the circuit on the surround vision system without having to take the camera out of the tailgate.
https://camera-source.com/automotive-cams/gm-oe-fit/2019-gm-1500-w-360-view-relocation-kit-with-camera-included.html
Did you get this camera? And if so, did it work as said? Can you give your description of it and evaluation?
Thanks, Morgan
I did. It's basically the exact same camera that's in the tailgate, wiring and all. It comes with an enclosure that you can mount anywhere. I have it on my camper. 100% recommend. Very easy install and works perfectly.
Does it plug into the disconnect that was under the truck or can it also plug into the dual plugs that are in the bed near the tailgate? It's hard to see in the picture.
Thanks
It plugs into the disconnected tailgate camera port. No way for it to plug into the ports on the bumper.
Well, I heard from Chevy. They sent it to their engineers. They said it was designed that way. Time to get new engineers. There was no recourse. They don't understand how may people need to remove the tailgate as they were too busy celebrating all the new cameras they designed. Pretty sad. Didn't even say they would look into it. Maybe when they start losing sales and getting more complaints?
On 2/4/2020 at 9:40 AM, Morgan Swisher said:
I have the Silverado, not the MultiPro but having trouble with other cameras not working after unplugging
I unplugged mine  no dummy plugs to protect wiring harness and no cameras were working
On 2/26/2020 at 4:10 PM, Morgan Swisher said:
How do you like that reese hitch extension? Does it hold up very well or in your opinion is the superhitch a better option? Trying to decide on which one for my 2020. Thanks
  • 6 months later...
I saw on this forum somewhere that a guy had researched and found the wiring harness that would plug in where the camera and tailgate lock controls plug into. He posted a pic of harness and part #. Now I can't find it and want to order one.
You don’t need a dummy plug or harness just to protect the connector. It is quite easy to bag the connector to protect it.     You also can get just a camera cable separately to hook up a replacement for the tailgate camera. I bought a gm tailgate camera of the same part number for $90, made an enclosure and installed it on the back of my camper. I bought my FAKRA cable from Pasternack.com for around $30.
