Wasn't the intake manifold gaskets (or the knock sensors) either.  After doing those, it now idles better, but the second you put it under a load (as in the second you put it in gear), it's just as bad as ever.
Pretty discouraged here, and out of ideas.
Intake was my thought too,does the motor skip from the second you start it? just thinking,open loop fine or not
Following the intake gaskets, it starts and idles well enough that I thought it might be fixed.  The second you put it in gear, it gets really rough.
Well, looks like we were all wrong.  Gave up and took it to a mechanic for diagnosis... just heard back, engine is bad. Will have more details once I pick it up.  Not happy.  Buying this truck was charity for a family member down on their luck and my reward is thousands out the window and nothing to show for it.
Engine is bad how?
That is what I'd be asking of the mechanic. Like a worn camshaft or like low compression on a cylinder?
"The engine is bad" is a VERY Generic Term that sounds a lot like "Whatever" . When you have over 200K, and the mechanics cant even make book on diagnosis, this is the result.
 While it might be cheaper to get a used engine with 150K , IF it really has a bad issue, I would want to know EXACTLY what is wrong.  COP OUT is a good way to describe this.
Yeah, I would expect a much more specific "diagnosis" than "the engine is bad" before shelling out for a new motor.  Did a roll of Benjamins happen to fall out of your pocket while talking to this mechanic?
  • 6 months later...
On 1/30/2020 at 1:43 PM, TedSJr said:
I have a 2003 2500 HD 4WD with 6.0 Gas V8.  The check engine light periodically will begin blinking.  It can blink for 2 minutes or for an hour, then it may quit for days.  It has been doing this for months.  My mechanic put it on the analyzer and got a Code 300.  He said it is a misfire but he cannot pinpoint where.  He suggested changing wires, plugs, coil packs, etc. Before I start replacing parts, does anyone have any thoughts?  I've read where people say you should stop driving the truck immediately but, like I said, it has been doing this for a while and I have no problems in performance or gas mileage.
I literally just went through this. My CEL would flash at highway speeds. I read somewhere that the crank sensor could be flaking out at higher rpm. I replaced the crank sensor this afternoon and just took it for a hard test drive on the highway. No More flashing CEL!  I also read that you need to do a crank sensor relearn after replacing it but right now, truck is running great so I think I’ll leave it alone. Hope this helps you!
  • 3 years later...
My 05 does the same thing…I replaced spark plugs and it ran great for a day…I replaced the coil packs and it ran great for a day again. I replaced the alternator and it ran great for 2 days. Wtf is up with these trucks?!?!?
    Frank V
    Frank V
  • Who's Online   5 Members, 0 Anonymous, 1,150 Guests (See full list)
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
