On 6/25/2020 at 10:13 PM, Stand By said:
Have you contacted White's or anybody to see if it could be programmed?
On 6/25/2020 at 8:51 AM, Zelas said:
I Have swapped out my Steering wheel with a Leather wheel which has the Buttons on the right. I also have swapped the Speedometer with a High Country one. It does not work . The Cruse control buttons work however, I have to reinstall my old speedometer because I am not able to toggle thru the menus. Its a bummer because it makes a huge difference in the interior.
I think you also have to swap the 7” monitor functions out for the 8” display model. That also carries all the information for this switch to happen. I have tried this but I’ve wanted too so bad.
  • 3 months later...
Did anyone find a way to add the buttons on the right?  Just got my 2021 2500HD Base and it doesnt have the volume on the right either.  The blank is there.  Can it be added?
After researching the addition of radio controls on the steering wheel, I've concluded it can't be done without a huge hassle and expense.  As an alternative, I swapped in the leather steering wheel and used the blank on the right side of the stock wheel that came on my 2020 Silverado Custom.  I have Katzkin leather seats so I wanted a leather wheel to match so at least I have a nice steering wheel instead of the cheezy plastic stock version that came on on the Custom trucks.  The cruise control buttons on the new wheel work fine.
Edited by Mac-427
  • 4 months later...
Someone on YouTube added the steering wheel controls on a 2021 Silverado custom.  And harness dr has the line bus harness to add steering wheel controls. But I believe you have to upgrade the cluster as well and swap steering wheel.
I was able to work with the Harness Dr on my 2021 Sierra 3500 base, to get this working. I added the programmed cluster from WAMS, a steering wheel with the menu controls on the right and audio controls on the back. We added 1 wire (now available on Harness Dr website), which required no splicing, pinned at the cluster and pinned at the clock spring harness and this gave my wheel full control. Well worth while upgrade.
Hey Vradcliffe, this is a  pretty big deal for lots of us on the Forum.  Any additional detail would be sincerely appreciated.
Hey Mac-427, I’ll try to add some detail so forgive the long post....
the first thing I would do is remover the upper steering column cover, to expose the clockspring harness (yellow connector). If you remove the harness, you can verify if there is any existing LIN bus connection (slot 9). If there is no connection, you should be able to run a wire directly from slot 9 at the clock spring along the existing harness to slot 20 at the cluster connector. I would really recommend going to the Harness Dr. website and purchasing the wire for $26. It will come with full instructions (many of the pics are from my upgrade, just saying that as verification it worked) and it is pinned perfectly to fit in the slots.
Just as an FYI, I DID NOT replace the clock spring, as I’ve seen many people believe that may be necessary for this upgrade.
This upgrade has had at least 2 additional successful attempts that I’m aware of, to this point.
Thanks Vradcliffe.  I'm following this issue closely because I have the steering wheel controls that came with my replacement leather wheel so I'm at least part of the way there.
@Vradcliffe,
Thanks again for your involvement in this.  Your patience and dedication to see this to fruition is greatly appreciated.
Foe those looking into this, the harness can be purchased here.
https://harnessdr.com/product/2019-2021-silverado-sierra-steering-wheel-lin-bus-harness/
A few things to note:
A new compatible cluster swap is needed.  The new cluster needs to be custom programmed by WAMS - 2019+ (T1) Denali / High Country Cluster Upgrade Kit - White Automotive & Media Services - @GTPprix is the only company I use for this type of work.
Since a new cluster is needed, might as well upgrade to the nicer Denali or High Country Cluster.
A few customers have also reported that they gained radio controls (IOR) radios and have restored backlight illumination on the left side.
Keep in mind, that this is still a fairly new retrofit and release - so individual results may vary.
Thanks!
On 6/9/2021 at 12:43 PM, Vradcliffe said:
Here are the before and after photos....
I apologize, the before photo is the dealer stock photo, I didn’t take one prior to the install...
That does make for a great look. Would happen to have the website where you ordered the parts?
Thanks!
I completed this and everything works except the heated wheel. Ordered a high country cluster from whites, wire from harness dr and a wheel from the dealer. Cost me about 1k to complete. Yes that's alot but its really nice..!! Since it's a custom the stereo bezel didn't match, I ordered the silver one to match.
Edited by Flatblack83
    250.6k
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 252 Guests (See full list)
    • I don't wanna do major surgery/upgrades, behind-the-dash work, add amps, change radio etc. on my '26 std cab WT. On the WT, it has the base 7" IOR infotainment setup, and only two speakers (doors). Since I listen to classical, looked around for speakers that do well and dug thru reviews. Two-way speakers were found to be better than 3-way. So I've ordered a pair of  Infinity Reference REF-9632IX 2 way speakers.  [These may  or may not have been discontinued / succeeded by the 3-way ...9633 ones.]    These speakers are lauded for 3 ohm and 94db sensitivity spec so they'll work well for ordinary base car radios without amps and offer better performance (quality,  strength) than  default base paper-cone speakers. They'll be installed in a few days and I'll let y'all know what I think. Bill W San Jose
    • Thanks!   Changed out the rear shocks today to Bilstein 5100s.  So far feel much better. The stock Rancho were wore out.  Lots of heavy hauling (2 moves, home renovations, etc).  Next up is new BFG tires Monday.  Cant wait the current tires have little to no wet traction and are super loud (hum)
    • Ok, I got the all the codes. What do you all think would be a place to start?
    • How about I just point to the factory pans stand pipe little drain plug and claim its a pan with a real drain plug !. I just couldn't swallow the fact that a Dorman pan which at this point is probably the only pan out there that fits the gas version truck cost that much up here in Canada so I decided initially anyway to skip it and see what I thought of pulling the pan method and down the road if I felt inclined enough then I would either install a drain plug kit in the factory pan if there is enough room for it, or have a bung welded onto it, or put an aftermarket pan on. The thing is if the pan is not pulled then the magnets in the pan can't be inspected and cleaned or if wanting to change out the filter. However of course it certainly would make the job easier to be able to drop the oil first before having to handle the pan if dropping the pan that go around was the goal.    I knew a guy locally that was doing custom field spraying years ago with a pickup pulling a ground driven sprayer, I believe it was a GM pickup with an automatic trans. He had a drain plug in his pan and would drop the oil out of it once a week and top it back up through the dipstick tube to keep refreshing a portion of the oil often and that made the transmission last far longer than had he done nothing. Soft fields pulling 500 gallons of water at the start of each mixed up sprayer tank batch and in low range sucking along. I imagine he got some tips from other custom sprayer outfits doing the same thing at the time and learning from their blown up tranny mistakes. Transmissions then had no lock up converter so would cook the crap out of the fluid slipping that much and it would not have been synthetic fluid either.
    • 3.39 Kroger’s in Montgomery Texas.
