My latest Silverado gripe
After a month without my truck for the brake/ESC debacle, I’ve had my truck back for two weeks with no issues! My joy was short lived however, because now the rear window is leaking based upon the big stain on the headliner. The dealership was great and set up an appointment for tomorrow and it will be out of commission for a few days. They said they’re seeing a lot of Silverado’s w/ the leak. They’ve been pulling down the headliner and addressing it from the inside, so we shall see. The Silverado Saga continues...
There is a large thread about this in the other forum section, i would check it out if i were you. Some dealers have been attempting to fix this with a half arsed caulking job, yes i said caulking as they have some junior tech gooping black silicone around the back window frame in a 9 times outta 10 failed attempt to fix the issue. The best fix so far has been a complete window and frame replacement, if this was me i would instantly demand this course of action for the fix and not allow some tech a attempt at bascally duct taping your truck for a fix.
Don't demand anything.  Ask firmly, but nicely.  You'll have better results.  If you try to make a scene you'll only make yourself look like an idiot.
Tell me about it!!!! Last week I took my 2020 TB to a touch less car wash with my 2 year old grandson... He was enjoying himself watching all the soap and water spray on the truck, He started like yelling and I look back and water is coming in the window and getting his car seat wet.... I have sent pictures to my dealership and GM of the wet spots on the headrest and back of seat and car seat.... Mine has a major leak... I have an appointment Monday morning to meet with the Service Manager and The president of this dealership... They have already offered to pay for a new car seat and fix the window leak.... They are also giving me a New Silverado With the Diesel motor to use while they work on mine...I requested a truck and asked about the Diesel, they said no problem... I’m happy how they are treating me so far about the issue, It’s the few months after the fix I’m worried about...
    • Very interesting thread. Definitely didn’t expect to see this kind of mileage out of that engine.
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
    • I had a evap sol go bad a couple weeks ago. . I replaced it.  While watching live data at the time I saw I had some cylinder 1 misfires. No MIL but on live data I could see ~50 at startup and about 70 more after an hour a drive all on cyl 1.  I also noticed that the LTFT were -5% to -15% always.  And that bank 2 is always -3% richer than bank 1. Even across all driving modes, city, highway, etc it’s always 3% richer than bank 1. So I start with the misfire. Swapped coil, plug, and plug wires from 1 to 3. No follow. I got an Injector reseal kit, pulled the D/s injector rail, swapped #1 and #3 injectors, resealed them, reinstalled and retested.  The misfire followed to 3. So I ordered and replaced all 8 injectors, spark plugs, and plug wires. Also replaced the 1 time use fuel pipes under the intake manifold.  Injectors that were in the truck since new were  Part # 12668390.  I replaced them with # 12742701 Got from RockAuto. Pretty certain they’re genuine and the correct ones. I called a friend at a parts store who told me “the 12742701 were the correct superseded part # for the originals I was replacing”. So started truck after replacing all that and it’s running -15 - -30 LTFTs. I reset the fuel trims with GDS2 and drove it for a 60 miles trip each way. There have been no changes in the LTFTs.  I checked if the HPFP was leaking into the crankcase. I removed the pvc and watched the trims. No difference.  I checked the alcohol content and it was at 10%  I’m out of ideas here. Truck seems to run great. Just always rich on the fuel trims.  Anyone with any help or ideas would be greatly appreciated.  I ran an injector balance test just for the heck of it and it came back this. I’m confused.  I have gds2 and some other diag tools if anyone knows of anything I should test next.
    • Definitely needs to go back to the dealer.
