Engine power reduced
i just stepped on the gas and all of a sudden engine power reduced popped up with a check engine light what would be the problem ? 2019 2.7 silverado
Why, so that they can tell him that’s normal? LOL!
Or by the time you get there it goes off and clears the codes.?
Could be many things.
Codes are not solutions, but they can shorten the diagnostic time.
Lots of reasons why it might think it needs to self-protect -- including 'false' readings from harness or sensor problems.
