I did a search and found one topic on the subject but was still not very clear... has anyone replaced their grill? I bought a blacked out one off of eBay and tried tearing into it today but couldn’t figure out how to remove the lower valence to gain access to the lower bolts on the grill. I could see 2 clips near the headlights but kept feeling like I was going to break it so I gave up and put it back together. Any tips would be appreciated.
8 minutes ago, silverado990 said:
Replaced my slt grill with a Denali grill. Tried to do myself ,gave up took to a Collision repair shop charged me $130. well worth it ,was told they had to remove bumper.
Perfect, that’s exactly what I needed to hear. Got as far as removing the upper tray top 4 bolts and felt liner on the passenger side before giving up. I’ll call around to some body shops on Monday and let them deal with it.
Don't have to remove bumper.  Have to remove valence.  Easiest place to find instructions is from any vendor of aftermarket bumpers.  It's not that bad.  Definitely not worth paying someone $130 if you're mechanically inclined.
Edited by Time2gofishing1980
This bumper is god awful (from my perspective anyway...) anyhow the it includes clear and concise instructions for grill and valance removal for anyone interested
https://www.carid.com/images/fab-fours/items/pdf/gr3900-1-installation-instructions.pdf
Update, grill is installed, wasn’t too bad only managed to break one clip near the headlight. Cheap grill off of eBay was a bad idea, it was mis manufactured and missing the mounting tabs for the top 2 10mm bolts as well as half of the sleeve to install the weather striping. I went ahead and installed it but will order the genuine gmc one and install it for replacement.
Edited by Kintnerboyredoubt
I'm going to agree and say that bumper is HIDEOUS.  Great job digging in and replacing the grill yourself though!
Based my my research, the first 3 minutes of this video would work for the GMC grill removal as well.  I am trying to see if there are any sensors that need reprogramming (for certain models like the denail's) by the dealer.   I want to add an LED Light bar and planned to try this method in the video below.
https://www.youtube.com/watch?v=nHJDxKdllbQ
Sorry to rain on your parade but the gmc grill has 3 10mm bolts on the bottom of the grill that have to be removed. The only way to access them is to remove the entire front valance. Would be a piece of cake if it were the same as the Chevy for grill removal. Good luck.
Thanks for the confirmation.
  • 1 year later...
Bringing back a slightly older post...
If you pull the front bumper (I have a base model without fogs, so I don't think I have any wires to worry about), can you sneak out the bottom bolts that hold in the grill?  Or is the lower valence under the grill still in the way from removing the bolts (and/or pulling the grill up)?
Thanks for any help!
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
    • We understand your frustrations with being unable to open your Sierra’s top inner tailgate, @smitty81503. Your concerns are frustrating, and we would like the opportunity to explore the best path of assistance to pursue their resolutions. There are many different factors that could be the root cause of vehicle concerns, and we handle each one on a case-by-case basis. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
