Anyone find a clean way to install a light bar on the front of the sierras yet? I know rough country has nice solution for the Silverado but I haven’t seen anything for the Sierra yet...
looking at the front end this morning and see a couple potential fastening locations, though they are higher up on the grille then ideal...  looking for ideas!
19 minutes ago, jeepincbum11 said:
I went lower with mine. Had to fabricate a mount. Took a couple hours. Still need to wire it up. 408100280d69221ca555a53e32cdb8b0.jpg55ef5d4b10ca5416dd4ab6c65022183f.jpg
Love that, any close up photos of how you mounted it?!
I put a aluminum bar across the supports that the angle iron lays on top of. I'll try to get better pics tmrw.39f9cffca5aa01cbd6e046821d697247.jpgf975953629c81d6a1296dd9e86ab04ef.jpg69c4123646ba552ca9649cd8a3abb0d1.jpge9bc49df77cea2a8db90a46e3ca6e071.jpg
Basically I cut a 34 inch aluminum L bar and mounted it with self tapping screws to the two lower air dam supports. I then ran L brackets with holes in it from the light to rest on the aluminum. Self tapped the two together for each side. It doesn't have to line up perfectly as the light side is adjustable. I did ensure the aluminum support bar was level. 0791057978df589a0b7140764c54a937.jpg7ab010e4f7a107d865f455607efbe2dd.jpge424240cee44898dd7f848af76ca50a1.jpga3b436153712391e5b5f03ac88cab2a8.jpg
I went high with mine. I was able to bolt them right to the bumper. Also, once you cut that huge plastic trim piece into two pieces, it’s way easier to handle lol.
Well,. I ended up not wiring to the high beams. I purchased a 12v 433mhz remote control relay from Amazon. Wired the light bar to it and it to the battery. Programmed the homelink button to the remote like a garage door opener. No wires needed to route through the firewall.
Link to relay. 12V Remote Control Switch 40A Power Switch Radio Controller, Wireless RF Receiver Switch 3000W 433Mhz Remote 2 Transmitter and Receiver,Wide Voltage DC12V - 48V https://www.amazon.com/dp/B07XK7D73Q/ref=cm_sw_r_cp_apa_i_q6CwEb7EHP941
I see what you did here and i like it my question is there a way to put the bar behind the bumper instead of infront if that makes sense?
This is what I did. Mounted them with 3M Auto Double sided tape. Sorry for the salt, got to love MN winters.
Edited by GMCSierra99
    Tbhats2130
    Tbhats2130
  • Who's Online   5 Members, 0 Anonymous, 1,238 Guests (See full list)
